  4. Weird problem after oil change
38 Posts 6 Posters 5.6k Views
  • B Bananper
    Is the basket supposed to sit really thight or should there be some movement? It's not very loose, just a tiny bit. Do i need to split the engine to change the bearing behind the basket?
    @bananper any movement will be highly exaggerated when the engine is running don’t use the bike you will easily destroy something my 250 is about 80nm I just stuck a ratchet on there and cranked it don’t (don’t do what I do)
    • F
      Am I the only one who's noticed the chunk missing from the pressure plate? Lol
      I'd like the know where the missing piece went
        @finnerz89 That's some beady eyes you have on you.
        Without that, the spring won't torque down properly.
        I can't say what real world difference that will actually make, but it might be enough to cause a problem.
        F 1 Reply Last reply
        • B
          B
          Bananper
          Yup, i'm getting a new pressure plate obviously. I took the bucket of, and the axle is moving a little bit, it shouldn't move right?
          • B
            B
            Bananper
            • B
              B
              Bananper
              #27
              Is this too much? It moves about 2mm
              https://youtu.be/3ZEvNP-LKpU
              • B Bananper
                @bananper that's fine
                  @calum I'm like a hawk mate 😂
                    @bananper If that engines been split, then they either haven't timed the engine correctly, or the clutch hasn't been assembled properly.
                    Either way easy job to fix, engine in the frame jobby.
                    B
                    B
                    Bananper
                    @calum i am starting to suspect the balancing shaft more and more... how do i go on to check it, and time it properly?
                    • B Bananper
                      @bananper Whip the clutch cover off, whip the clutch basket off.
                      Rotate the crank shafter around. The two dots on the primary shaft cog and the balancer shaft cog should meet. If they don't then the timing is out.
                      It does destroy bearings, but you should get away with just sorting it.
                      If it's not that, then it's either a rough engine, clutch imbalance or lose/worn engine mounts.
                      B 1 Reply Last reply
                        B
                        B
                        Bananper
                        @calum alright, so if it's not alligned, do i need to split the case? Sorry i'm really inexperienced with these type of engines😂
                        • B
                          B
                          Bananper
                          So they're alligned
                          http://imgur.com/K18333q
                            Cool that looks good then. Now you just need to make sure the clutch is balanced properly.
                            No you don't need to split the cases. You just set the piston to TDC.
                              B
                              B
                              Bananper
                              @calum maybe a stupid question but how do i balance the clutch, do i need anything special to do it?
                              • B Bananper
                                @bananper No. The clutch goes in a special order. I wrote a tutorial on here under kick start conversion. Should be on Tutorials forum
                                • B Bananper
                                  @bananper please try tightening your engine mounts my mate had a cr85 the engine was solid but it was actually loose
                                    B
                                    B
                                    Bananper
                                    @calum have you looked at the video i linked above? Do you think it's to loose? Could the bearing be the problem
