  4. DT125R NINJA Project
19 Posts 5 Posters 11.8k Views
  • NINJAN Offline
    NINJAN Offline
    Hi All -
    I bought this DT as I had the original DT125LC back in the day and I decided that as I am at a mature age now, a decent motorbike would be a sweet way to get around and avoid sitting in traffic etc. So I looked around and hunted for a decent one and eventually I found this baby;
    Anyways she wasn't quite to my liking, but only had a genuine 7K on the clock, plus it was the first bike which came with a clear HPI report, So I won her on ebay and decided to give her a refresh, I'm not after a total revamp, just some customisation, to give her an individual look. The bike has had the exhaust restrictions removed, a DEP rear silencer, a jack up kit and some braided brake lines, but other than that she's pretty much standard. The first thing I did was to get hold of some stock suspension dog-bones to return her back to the stock ride height, as she was just a bit too tall for my lil ole legs! LOL
    Also one of the previous owners added a 12V socket to the 2ST oil side panel and totally mutilated it. So the first thing I ordered was some new panels. I also ordered some new mudguards, decals and a new 3D number plate as well. I decided that I wanted to keep the bike as a pretty much all black bike, with a Ninjaish twist for that stealthy look. Ie. A bit of chrome and a splash of blood red, just to switch her up a bit. So the first thing I decided to do when I got the panels was to carbon wrap them for a more modern look. i also stuck some heat shield to the rear of the side panels for some protection too.
    Here's my first steps;
    I also put some LED blinkers on the rear but just can't get all 4 to work if I add the front one's. I tried the load resistors and an LED relay but sadly no joy, so I may go with some different one's. I have an LED rear light and a tail tidy to add to her next.
    • mad73M Offline
      mad73M Offline
      mad73
      looks nice and clean m8
        Nah that's properly clean. A tail tidy would work a treat.
        That's lovely though. If you keep it standard then it'll be worth a mint in years to come.
          NINJAN Offline
          NINJAN Offline
          Thanks guys;
          Here's my latest handy work, I'll take some better pics of the rear end tomorrow hopefully, so long as the darn rain holds off!!!
          I fitted some Barkbusters hand guards, headlight graphics, tank decals, carbon wrapped the chain guard and resprayed the yucky front chain guide too. I fitted the tail tidy, rear reflectors and resprayed the front pipe and heat shield as well. She's starting to look more like how i imagined her too now!!! :O)
          4
          • Biker_123B Offline
            Biker_123B Offline
            Biker_123
            Good job so far! liking your work the bike looks unique
            Every problem has a solution
            • MiniaM Offline
              MiniaM Offline
              Minia
              Man, that is such a good looking bike! Keep up the awesome work!
                Thanks guys;
                NINJAN Offline
                NINJAN Offline
                Thanks guys, so here's my current mod/wish list.
                Upgraded brakes
                Alloy rims & maybe new hubs too
                Avon Trailrider tyres
                OSD forks
                New bars
                New seat cover
                Maybe new swingarm. [I really like Dartys YZ rear end build, but not sure if I will follow his work as yet].
                I may then set about tuning the engine, not sure if I'll just go mild with carbon reeds, air filter etc. Or go the whole hog with a 170cc kit? But that's a long way off if I choose to go down that road or not? As I'd really like to get my full licence and get rid of these butt-ugly L plates first!!!! LOL ;O)
                  Upgraded brakes
                  OSD forks
                  New bars
                  New seat cover
                  NINJAN Offline
                  NINJAN Offline
                  @CYBER-NINJA Which wheel hubs are directly compatible with the DT? I'm guessing a lot are, so long as the spindle is the right thickness and you just use the right size spacers to centralize the wheel? Or am I totally wrong and they all different for each manufacturer? I'm guessing that the WR and YZ hubs are a direct fit, but what else is too please???
                  Thanks
                    Thanks
                    @CYBER-NINJA Wrong on that one pal.
                    You can't just go willy nilly changing wheels. Centralising the wheel to the swingarm doesn't achieve much. You must have the front and rear wheels inline. Then you must get the front and rear sprocket in line. Failure to do so will not end well.
                    Eventually I had to machine down the rear brake carrier to get everything centralised my end. Was a right faff!
                      NINJAN Offline
                      NINJAN Offline
                      @Calum OK so the simplest solution is to use the existing hubs and just get the wheels rebuilt with alloy rims. As that way there will be less faffing around with lining everything up, but the issue would then be getting a larger front brake disc to fit the DT's 3x2 bolt pattern. However what if I used the stock rear hub and a WR or YZ front hub? Would that all line up if I used the correct spacers? As that would give me a better bolt pattern for a larger front disc too???
                        NINJAN Offline
                        NINJAN Offline
                        A Few new pics of my latest upgrades - Enjoy!!! ;O)
                        Added;
                        Wing mirrors with some carbon wrapping.
                        TrailRider tyres F-90/90/21 & R-120/80/18.
                        New tubes
                        Kyoto Wavey discs
                        EBC Red stuff pads
                        Arrow indicators
                        Resprayed the swing arm, rear caliper bracket, chain tensioners, spokes & hubs, brake pedal, kick starter and shift lever.
                        Removed Air bottle.
                        Coloured YAMAHA seat logo in Red.
                          Biker_123B Offline
                          Biker_123
                          Dang that is looking mighty fine!! Nice upgrades mate that DT definitely stands out from the crowd whilst still maintaining the original look good work so far liking it 👍🏻
                            YEah that looks well smart I like the graphics on it.
                            • NINJAN Offline
                              NINJAN Offline
                              Thanks guys. I got the decals from this dude;
                              http://www.ebay.co.uk/itm/Yamaha-DT-DTR-125-200-1988-2004-Decals-Graphics-Sticker-Kit-All-Colours-non-oem-/262534208077?hash=item3d20421a4d:g:UMcAAOSwubRXHnei
                              You may know him he did a DT200/125 conversion?
                              http://www.ebay.com/itm/YAMAHA-DT-R-125-Mint-Condition-1989-with-DT200-suspension-dual-Rads12-Months-MOT-/252172932230?nma=true&si=zVJzW6IbgiWU2E9kYOg3tY%252BlUKg%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
                              • NINJAN Offline
                                NINJAN Offline
                                Well sadly this beauty is now up for sale, as I need to fund my next project. Full details can be found here;
                                https://www.gumtree.com/p/yamaha-motorbikes/yamaha-dt125r-2003-black-excellent-condition-and-very-well-looked-after-example-/1182949941
                                  @CYBER-NINJA Aww good luck buddy,
                                  It should be a good bike for somebody else no doubt!
                                  • NINJAN Offline
                                    NINJAN Offline
                                    Well sadly the bike was sold today. She was a damn fine lady and a pleasure to own. Hopefully the new owner will keep her looking and running sweet? After being out of the saddle for 30 years I've really enjoyed riding her immensely! I'll miss the ole girl for-sure, but hey ho onto new adventures we go..............
                                      @CYBER-NINJA What's the plans then buddy??
                                        NINJAN Offline
                                        NINJAN Offline
                                        @Calum SuperMoto here we come! You may have to add a specific SM section soon!!! LOL ;O)
