  3. Other
  4. the yzf project
the yzf project
29 Posts 6 Posters 16.3k Views 1 Watching
  • mad73M mad73
    darty I would love a rgv250 that would prob leave my 750 round the lanes
    biker 123 I use a soldering iron , what I do is start just before the crack in small circles mixing 1 side to the other about 2-3 mm deep both sides of the panel then stop just after the crack its quite a strong fix never had a panel re-crack on me ,then just rub down and fill , as for a hole if u can cut a piece of another panel u can weld it in with the same method I have some pics of a single seat unit I made and it worked out really well , hope this is some help to u if u need more help when doing just pm me
    Biker_123B
    Biker_123B
    Biker_123
    @mad73 Thanks for that mate very helpful!! Yes I have a soldering iron here so I'd be able to give it a shot on the panels using your method 😃. I'll probably sit down in the next week or so and give it a try need to strip the graphics of the panels first and give them a good clean .
    Every problem has a solution
    • mad73M
      mad73M
      mad73
      got this in the post today little tatty but its only for mot , its for a fzr 400 but I'm sure it will fit
      http://i286.photobucket.com/albums/ll115/mad73_2008/ex_zpsqjefm542.jpg
      http://i286.photobucket.com/albums/ll115/mad73_2008/exhaust_zpsahp4iejn.jpg
      • mad73M
        mad73M
        mad73
        got these today and they fit nicely in the r1 clock bracket only 30 quid just hope they work ok wont no for a few weeks yet
        http://i286.photobucket.com/albums/ll115/mad73_2008/clocks_zpsgrjpzlvy.jpg
        http://i286.photobucket.com/albums/ll115/mad73_2008/clocks and bracket_zpsvu8qtcet.jpg
        • mad73M
          mad73M
          mad73
          • mad73M
            mad73M
            mad73
            don't no why it wont show the image ?
            • mad73M mad73
              Looks like a photo bucket error of some kind. I haven't got a computer at the moment so cannot investigate.
              • mad73M
                mad73M
                mad73
                this happens a lot on my posts
                • mad73M
                  mad73M
                  mad73
                  its in the shed now, been looking around it and what a mess needs a dam good scrub ,
                  http://i286.photobucket.com/albums/ll115/mad73_2008/dirt_zpsqvccawyg.jpg
                  http://i286.photobucket.com/albums/ll115/mad73_2008/grime_zpsqrxyjtxg.jpg
                  http://i286.photobucket.com/albums/ll115/mad73_2008/more_zps1wrrb2ya.jpg
                  test fitted the seat unit shouldn't be to hard to fit will need to cut and remake the sub frame need to get it up higher as u can see for the pics also need to extend it needs to meet the fixing points http://i286.photobucket.com/albums/ll115/mad73_2008/extened_zps1lf991ot.jpg
                  http://i286.photobucket.com/albums/ll115/mad73_2008/test_zps4ajnvyqx.jpg
                  http://i286.photobucket.com/albums/ll115/mad73_2008/sub_zpshqwrllto.jpg
                  been trying to get the gaffer tape off the fork as the monkey before me who had it thought it would be good to put it round the forks to take the headlight brackets as it was fightered
                  http://i286.photobucket.com/albums/ll115/mad73_2008/tape_zpsd14wg6oc.jpg
                  well got my work cut out I think
                    Dayum, I actually quite like the pink wheels.
                    • mad73M
                      mad73M
                      mad73
                      nice Yamaha 90s colours they aint staying pink will b black
                      • mad73M
                        mad73M
                        mad73
                        bit more done this weekend got the sub frame cut down and welded up so its all hidden not the best welding buts its strong enough aint got to carry an weight
                        http://i286.photobucket.com/albums/ll115/mad73_2008/pi_zpsx6yjkrxk.jpg
                        http://i286.photobucket.com/albums/ll115/mad73_2008/fix_zpsuf4hx2fs.jpg
                        test fit before painting
                        http://i286.photobucket.com/albums/ll115/mad73_2008/fitted_zpskkthcugz.jpg
                        http://i286.photobucket.com/albums/ll115/mad73_2008/trial_zpskpy6y1hh.jpg
                        quick coat of satin black
                        http://i286.photobucket.com/albums/ll115/mad73_2008/done_zpsz3kec0nz.jpg
                        found petrol leaking from my tank so that's another thing to fix the list is getting bigger
                        http://i286.photobucket.com/albums/ll115/mad73_2008/hole_zpsi8vog7mp.jpg
                        had a few goodies delivered yesterday heavy duty springs and clutch plates and short levers
                        http://i286.photobucket.com/albums/ll115/mad73_2008/new_zps1snkokpa.jpg
                        http://i286.photobucket.com/albums/ll115/mad73_2008/levers_zps1gibbjbq.jpg
                        • mad73M
                          mad73M
                          mad73
                          ok been quite a while since last update , got quite a lot done in the 4 month its nearly finished wont put pics up yet of how I sprayed it will leave till its back together ,
                          clutch done , forks rebuilt carbs on and running but not right , wont run unless on choke should be just carbs need balancing , was surprised how easy it started as it has sat for nearly 5 years
                          all sprayed except clear coat , having trouble setting up digital dash will put another post up on that for help if any one can help with them ,
                          wiring repaired where needed
                          http://i286.photobucket.com/albums/ll115/mad73_2008/fit_zpscggs0ou6.jpg
                          test fitted the body work
                          http://i286.photobucket.com/albums/ll115/mad73_2008/test_zpsoupp6wzh.jpg
                          as you can see its not sitting right but soon sorted that
                          http://i286.photobucket.com/albums/ll115/mad73_2008/ppoiuygvcds_zpsbbqfkc7a.jpg
                          http://i286.photobucket.com/albums/ll115/mad73_2008/ppoiuuy_zpsbo3c1wid.jpg
                          filled all the holes in the side panels as they were cut out for crash bungs on the r1 they came off and didn't line up with my frame all so filled the indicator holes as mine are built into the mirrors
                          http://i286.photobucket.com/albums/ll115/mad73_2008/kjkihygt_zpskuvpxa8a.jpg
                          http://i286.photobucket.com/albums/ll115/mad73_2008/kjujhyfg_zpsqo7ylmul.jpg
                          tank had a few little dents so filled all them
                          http://i286.photobucket.com/albums/ll115/mad73_2008/lined_zpsdvmjtde9.jpg
                          all primed and started to mask up the lines I wanted
                          I will say it hasn't come out as well as I hoped but still good enough for a diy job
                          more pics to come soon
                            Hey its looking good bud. You certainly have been keeping busy!
                            You got an eta fow when it will be done.
                            mad73M 1 Reply Last reply
                              mad73M
                              mad73M
                              mad73
                              @Calum Well was gona use it this summer in just primer but I thought might as well finish it hoping it will be back together by end of the month leaving just odds and end to finish might get to get out on it a couple of times this year will have to see how it goes . This is just eating money the £800 that I had to sort it has gone no where I'm nearly double that and still got at least another £350 to put in to it
                                Yeah but cmon, built nor bought right
                                • mad73M mad73
                                  @mad73 said in the yzf project:
                                  The joys of restoring and customizing your mean machine! All will be forgotten when you're blasting around the twisty's with a massive grin on yer boat race!!! 😉
                                  • mad73M
                                    mad73M
                                    mad73
                                    that's why I have kept going with it ,, its only money lol
                                    • MightymanM
                                      @CYBER-NINJA And then you'll suddenly remember again when it's inevitably time to sell up 😂
                                      • mad73M
                                        mad73M
                                        mad73
                                        Yeah that is the flip side how much is too much coz I will never get it back
                                        So far I paid £600 for the bike I've done about £1400 getting it to where it is now + I have more to spend I would think by the time I've finished it will stand me in at about £2500 and it will prob be worth about £1600 on a good day , but I didn't do it to make money just to have something different and learn a bit on the way . The yzf750 was prob the best 750 of its time it still rocks by today's standards of 600s it more bike than I can handle
