DT200WR restoration project pic heavy
@Calum cheers dude. Yes and more to come... Hopefully tomorrow.
Only thing that might delay this project is that shock bearing + collars... Knowing how everyone always sends the wrong part
@Calum yes a few people but I will need to do a drawing.. they don't like doing free hand jobs and programming for a small quantity isn't what they want
Without this seal , you might as well not have an air filter. So I made a new one
New twin air filter on the way..I literally spent a hour cleaning bolts an fitting... But it has to be done
Even though the seat cover was in good condition, I wanted baby blue + Yamaha logo
One of my least favourite jobs... 2hrs of tweeking..
I will let it shape over the weekend and then give it a final stretch.
I like the red to match the forms and purpose to match the frame.. the graphics are blue and purple so the seat will make sense.
Shock absorber came up nicely (no paint ) might consider re painting spring
Wow, those handlebars are gorgeous!
Might not be a bad shout to get the shock repainted, either to that original pink, or to adhere to your scheme.
Looking sweet.
@Calum glad I choose red .. cheers, shock is in very good condition for age, the soft-hard adjusters work with ease. I'll keep it pink
@Minia even more Gucci bits here..
Very pleased with the quality of the graphics. Full set but not shown in picture.
Sorted out the shocks top bearing now.
Blanked of carb warmer outlets on cylinder head.
New clear hoses came.
And this arrived.
And this arrived.
@Calum said in DT200WR restoration project pic heavy:
@Louis-James Oh wow, be almost criminal to use that!!!
If it was OEM
but a £38 Chinese copy -
If it was OEM
If it was OEM
@Louis-James WOW clocks look damn good for a copy. Post a link dude as others may wanna grab some.
@NINJA Speedometer Kilometer Odometer Gauge Tachometer Clock Instrument Gauges Assembly For Yamaha DT125R DT200R DT200WR DT 125 200 R
https://s.click.aliexpress.com/e/bewqNZY5 -
So , the silver parts were ready and the exhaust expansion was blasted..
I may upgrade to a FMF system or dep. And sell this exhaust.Started prepping bits for assembly. Tapping holes etc.
As suspected not all wires on the new clocks were correct.
New clocks had a blank where the oil light is and a completely fake temperature light..
So I transfer all original loom onto the new clocks and drilled a hole for the temp light and put a long bulb holder in to hold the bulb close to the "red" window
New temp light
Brand new fully functional clocks at a fraction of YAMAHA cost:
New temp light
