DT200WR restoration project pic heavy
@Minia even more Gucci bits here..
Very pleased with the quality of the graphics. Full set but not shown in picture.
Sorted out the shocks top bearing now.
Blanked of carb warmer outlets on cylinder head.
New clear hoses came.
And this arrived.
And this arrived.
@Calum said in DT200WR restoration project pic heavy:
@Louis-James Oh wow, be almost criminal to use that!!!
If it was OEM
but a Β£38 Chinese copy -
If it was OEM
If it was OEM
@Louis-James WOW clocks look damn good for a copy. Post a link dude as others may wanna grab some.
@NINJA Speedometer Kilometer Odometer Gauge Tachometer Clock Instrument Gauges Assembly For Yamaha DT125R DT200R DT200WR DT 125 200 R
https://s.click.aliexpress.com/e/bewqNZY5 -
So , the silver parts were ready and the exhaust expansion was blasted..
I may upgrade to a FMF system or dep. And sell this exhaust.Started prepping bits for assembly. Tapping holes etc.
As suspected not all wires on the new clocks were correct.
New clocks had a blank where the oil light is and a completely fake temperature light..
So I transfer all original loom onto the new clocks and drilled a hole for the temp light and put a long bulb holder in to hold the bulb close to the "red" window
New temp light
Brand new fully functional clocks at a fraction of YAMAHA cost:
New temp light
@NINJA I'm not sure , I just asked for a semi gloss silver powdercoat
Looking pucker mate.
Definitely making me itch for another project! Although no way I can afford to do this at the pace you're doing it at!
What ya do, rob a bank?
@Calum cheers Val. And tbh parts I have spent less than Β£200, powdercoating Inc sandblasting and special paint colour Β£180
@Louis-James said in DT200WR restoration project pic heavy:
OK Cool I wasn't sure if it was powdercoat or anodising???
@NINJA oh it's all powder
Now the rebuild begins.
New chain guard courtesy of AliExpressΒ£11 not bad
Looks so much nicer in person... Really has that 90s yz feel
Contrast
Whacky colour mix
As she sits now... Going to take my time and enjoy it
Contrast
Whacky colour mix
@Calum probably like Marmite some for people, but I'm daring, it will all make sense when finished.
Thanks, where to? Be good to pull in some newbies
