  4. Speedo works but odometer doesn't
14 Posts 5 Posters 890 Views 1 Watching
  • S Offline
    seamusdt
    Hi guys any help/info would be greatly appreciated, 07 dtre as the title suggests speedo working odometer doesn't and the trip meter and knob are missing. Any ideas if its repairable or will I need a replacement??
    NINJAN 2 Replies Last reply
    • NottsbikerN Offline
      NottsbikerN Offline
      Could just be a broken cable have you checked that first?
      • S seamusdt
        NINJAN Offline
        NINJAN Offline
        @seamusdt As stated its most likely a broken cable or faulty worm drive???
        • S Offline
          seamusdt
          Cheers guys i'll try and source a cable and give that a try 👍
          • S seamusdt
            D Offline
            D Offline
            If the speedo works I doubt it'll be the cable, sounds like the speedo unit has suffered some damage, probably easiest to replace speedo unit unless you can find another spares one to cannibalize for parts.
            • D DTR+NSR
              seamusdt
              @DTR-NSR I can only find 1 speedo on eBay and thats 150sheets might be better with an aftermarket one???
              • S seamusdt
                D Offline
                D Offline
                Probably the cheapest option but I've no idea what the quality of them is like.
                • S seamusdt
                  NINJAN Offline
                  NINJAN Offline
                  @seamusdt You would probably be better off buying a copy and using that for spare parts for the original unit;
                  https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20190401105823&SearchText=DT125r+Speedometer
                  • F Offline
                    F Offline
                    I'd go aftermarket - I can recommend the trailtech vapor
                      NINJAN Offline
                      NINJAN Offline
                      @finnerz89 I would agree with aftermarket, I have the Koso DB-03R and can highly recommend it. But again its the cost which is a factor???
                      F 1 Reply Last reply
                        F Offline
                        F Offline
                        @NINJA I think my trailtech kit cost me around 130, how much is a replacement from Yamaha?
                          NottsbikerN Offline
                          Misread original post as rev counter not odometer doh
                          I had Veypor speedo on my last DT and was very good quality
                          Just picked up an X unit for my DT200WR as the original is km and that was 40 quid for the whole thing used
                          • S Offline
                            seamusdt
                            I found a guy breaking one 50quid delivered 👍
                              NottsbikerN Offline
                              Bargain 🙂
