Speedo works but odometer doesn't
Could just be a broken cable have you checked that first?
Hi guys any help/info would be greatly appreciated, 07 dtre as the title suggests speedo working odometer doesn't and the trip meter and knob are missing. Any ideas if its repairable or will I need a replacement??
If the speedo works I doubt it'll be the cable, sounds like the speedo unit has suffered some damage, probably easiest to replace speedo unit unless you can find another spares one to cannibalize for parts.
@DTR-NSR I can only find 1 speedo on eBay and thats 150sheets might be better with an aftermarket one???
@finnerz89 I would agree with aftermarket, I have the Koso DB-03R and can highly recommend it. But again its the cost which is a factor???
Misread original post as rev counter not odometer doh
I had Veypor speedo on my last DT and was very good quality
Just picked up an X unit for my DT200WR as the original is km and that was 40 quid for the whole thing used
Bargain
