  3. DTRE
  4. Front forks for 04 dt125re
dt125suspensiondtredt125x
14 Posts 5 Posters 3.3k Views
  • clawsC Offline
    clawsC Offline
    claws
    What front forks would go on my dt? Preferably upside-down ones and without having to mod the triple clamps to fit the bike
      None, USDs are huge. You need to use matching triple clamps.
      It's not the biggest job in the world, but certainly makes a big difference.
      The easiest thing to do is go swap out the whole front end. Wheels and brakes.
      I have written a guide on a proper way to do it.
      clawsC 1 Reply Last reply
        clawsC Offline
        clawsC Offline
        claws
        @Calum no but like i can go for new triple clamps just that i dont have to mod them to the frame. i cant get new wheels since it would probably cost alot more than i can afford. but i will check your guide out
        • clawsC claws
          @claws if money is a limiting factor then leave the bike alone. Modifications are rarely cheap.
            clawsC Offline
            clawsC Offline
            claws
            @Calum i could probably find used forks for a good price maybe. gotta go to work again lmao
            • clawsC claws
              @claws I’d leave it mate, you may get infinitely lucky and pick a set up that directly bolts in but the chances of that would be extremely slim as per @Calum guide you need custom spacers etc it’s not the worst thing in the world to do but you need to be committed to the job and doing it properly you can’t really short cut this
              • clawsC claws
                NINJAN Offline
                NINJAN Offline
                @claws See here bud, this set-up is probably the closest you will get to a straight bolt on mod for USD's. It still required one spacer and the whole front end from an Aprilia MX 125, but the thread shows whats needed.
                https://dt125r.co.uk/topic/1020/dtdr-build
                But @Calum guide is very comprehensive, but again spacers are required. Also see this thread;
                https://dt125r.co.uk/topic/49/a-fairly-complete-list-of-41mm-forks-these-will-fit-directly-into-dtr-and-dtre-x-yokes-p
                  clawsC Offline
                  clawsC Offline
                  claws
                  @NINJA welp i ended up buying "new" forks for my dt since the ones i have are in bad shape
                  • clawsC claws
                    @claws That sounds a bit overkill? Could you have not had your forks rebuilt? Can get the stanchions rechromed if they were damaged.
                      clawsC Offline
                      clawsC Offline
                      claws
                      @Calum welp i got them for a good price and i cant be arsed to get the forks rebuilt or do it myself
                      • Walney-ReptilesW Offline
                        Walney-Reptiles
                        @claws get some photos of you bike up? 🙂
                          clawsC Offline
                          clawsC Offline
                          claws
                          @Walney-Reptiles sure
                          • clawsC claws
                            Walney-Reptiles
                            @claws Nice where did you get those rims? iv been looking every were for a set
                              clawsC Offline
                              clawsC Offline
                              claws
                              @Walney-Reptiles actually bought the bike with the rims already on. kinda sad that i don't have the enduro wheels as well but no can do. and i think that the wheels are from a wr125x
