Dtre 125 autolube help please
Hi so ive just bought a dtre 125 2004 model and the guy was using a different 2 stroke oil so ive taken off the pump and bottle ect and to clean it i used petrol so ive stripped down the pump and now for some reason the pin underneath will not move back up into the slide sort of looks like the valve in a carb and i cant line it back up what do you lot think if it a nee oil pump or csn i rebuild it somhow. Thanks
@claws said in Dtre 125 autolube help please:
i would suggest not using the autolube and mixing the oil with the gas
GAS? WTF! Are you running on propane or natural? Petrol please!
@NINJA said in Dtre 125 autolube help please:
@itstom Carb For future reference some carb cleaner would have been a better option.
Even carb cleaner destroys o rings, can get oil pump refurbed if needs be, or s/h off eBay?
@oldman i mix the 2 stroke oil with the gas. i use a 2% mix and not need to worry about autolube. works great
It's petrol! Not gas
@oldman does it matter? i say gas if i want to and you can say petrol. im not from the uk so i dont say petrol
