  4. Why doesn't my DT125 get a spark?
electricsstatorcdisparkcdi. power. dt
39 Posts 7 Posters 7.8k Views
  • clawsC claws
    @NINJA welp the positive thing is that now i have a valid reason to get an inner rotor kit
    @claws If you've got the cash then Go_4_it!!! 😉
      Uhhmm
      Inner rotor kits aren't that great for road going machines.
      You won't be able to run lights, charge the battery etc.
      Great for racing machines. But then you'd want a lighter chassis etc.
      clawsC 1 Reply Last reply
        Uhhmm
        clawsC
        clawsC
        claws
        @Calum yea i know the disadvantages but its actually going to be cheaper to get an inner rotor kit than to get a brand new stator and i don't know if i would trust ebay
        • clawsC claws
          @claws Well I have sold loads of stuff on eBay. So you're implying I sell dodgy gear.
          There are genuine sellers on eBay.
          That being said, I have bought some right nails before. But price was right.
            I have spares, not for sale though🙁
            • O oldman
              @oldman Thanks...keep us posted on that 😛
                I like to be helpful😉
                  clawsC
                  clawsC
                  claws
                  @Calum oh yea and the thing is that there arent any correct stators for sale there. only 2003 or older when i need a 2004 or newer stator
                  NINJAN CalumC declanD 3 Replies Last reply
                  • clawsC claws
                    @claws Try the FB owners groups or these guys, they may have one???
                    https://dt125r.co.uk/topic/562/parts-suppliers-database/5
                    • clawsC claws
                      @claws I can't remember, Did the belgarda stator also work. Cause I ran the belgarda engine on my RE ignition. Or did I swap the starter
                      Either way, check the electric start TDRs if they were ever a thing.
                      O 1 Reply Last reply
                      • clawsC claws
                        @claws I saw one just yesterday for 30 pound on ebay
                          Not sure if this is that same one I saw,
                          https://www.ebay.co.uk/itm/Yamaha-DTR125R-Generator-Stator-Plate-3BN-85560-00/183922475348?epid=644688643&hash=item2ad2a24154:g:-ycAAOSwsS9dTX0Z
                            #36
                            @Calum said in Why doesn't my DT125 get a spark?:
                            They were:) have one of those too!
                            • O oldman
                              clawsC
                              clawsC
                              claws
                              @oldman are the stators plates or what ever they are called that hold them in the right place screwed onto the block or the magneto cover?
                              • M
                                M
                                Mike1992
                                @claws I had the same problem with my DT125X !!
                                Turned out to be the wiring had come loose. You will need to remove your seat and tank and get ready to start undoing copious amounts of electrical tape!
                                Once all tape is out of the way you will find a big bunch of black wires terminated together! This termination is standard from factory at Yamaha. It looks like a big blob of solder is connecting them all together.
                                To be honest it took me a while to finally figure out this was the fault as the connection looks really good and strong however there are so many cables in there and the connect was the problem.
                                Instead of re terminating the cables I tied a cable tie tight around the neck of the bunch and that solved the issue, Spark plug now Sparks!
                                Hopefully this helps and get your plug back sparking !!
                                Mike
                                • M Mike1992
                                  Mike
                                  clawsC
                                  clawsC
                                  claws
                                  @Mike1992 well the issue was that one wire had broken and after one evening of riding and doing some wheelies my stator blew and now im looking for a new one
