  4. Why doesn't my DT125 get a spark?
electricsstatorcdisparkcdi. power. dt
39 Posts 7 Posters 7.8k Views
    I have spares, not for sale though🙁
    • O oldman
      @oldman Thanks...keep us posted on that 😛
        I like to be helpful😉
          @claws Well I have sold loads of stuff on eBay. So you're implying I sell dodgy gear.
          There are genuine sellers on eBay.
          That being said, I have bought some right nails before. But price was right.
          clawsC
          clawsC
          claws
          @Calum oh yea and the thing is that there arent any correct stators for sale there. only 2003 or older when i need a 2004 or newer stator
          NINJAN CalumC declanD 3 Replies Last reply
          • clawsC claws
            @claws Try the FB owners groups or these guys, they may have one???
            https://dt125r.co.uk/topic/562/parts-suppliers-database/5
            • clawsC claws
              @claws I can't remember, Did the belgarda stator also work. Cause I ran the belgarda engine on my RE ignition. Or did I swap the starter
              Either way, check the electric start TDRs if they were ever a thing.
              O 1 Reply Last reply
              • clawsC claws
                @claws I saw one just yesterday for 30 pound on ebay
                  Not sure if this is that same one I saw,
                  https://www.ebay.co.uk/itm/Yamaha-DTR125R-Generator-Stator-Plate-3BN-85560-00/183922475348?epid=644688643&hash=item2ad2a24154:g:-ycAAOSwsS9dTX0Z
                    #36
                    @Calum said in Why doesn't my DT125 get a spark?:
                    They were:) have one of those too!
                    clawsC 1 Reply Last reply
                    • O oldman
                      clawsC
                      clawsC
                      claws
                      @oldman are the stators plates or what ever they are called that hold them in the right place screwed onto the block or the magneto cover?
                      • M
                        M
                        Mike1992
                        @claws I had the same problem with my DT125X !!
                        Turned out to be the wiring had come loose. You will need to remove your seat and tank and get ready to start undoing copious amounts of electrical tape!
                        Once all tape is out of the way you will find a big bunch of black wires terminated together! This termination is standard from factory at Yamaha. It looks like a big blob of solder is connecting them all together.
                        To be honest it took me a while to finally figure out this was the fault as the connection looks really good and strong however there are so many cables in there and the connect was the problem.
                        Instead of re terminating the cables I tied a cable tie tight around the neck of the bunch and that solved the issue, Spark plug now Sparks!
                        Hopefully this helps and get your plug back sparking !!
                        Mike
                        • M Mike1992
                          Mike
                          clawsC
                          clawsC
                          claws
                          @Mike1992 well the issue was that one wire had broken and after one evening of riding and doing some wheelies my stator blew and now im looking for a new one
