  4. Project DTZr.....a DT125R love story
80 Posts 14 Posters 23.5k Views 1 Watching
  • MadGyverM
    MadGyverM
    Plastics repair.
    Plastics where damaged and brush painted with car chassis paint.Grey stuff is putty for plastics.
      Looking very smart bud. Loving the fact you're "Keeping it within the family" so to speak...
      MadGyverM 1 Reply Last reply
      • MadGyverM
        MadGyverM
        The crank before and after.
        • MadGyverM
          MadGyverM
          The cracnkcases,before and after cleaning and smoothed/matched/checked inside
          TZR 125 2RH gearbox (one model of the old TZR had the same gear ratios with the TZR 125RR Belgarda),that one is fitted.
          Had to find some different bearings to install,not same with the DT.
          • MadGyverM
            MadGyverM
            Repairing a hard to find DT200R 3ET alloy swing arm,and this considered good condition.
            3
            • MadGyverM MadGyver
              Louis-DT-WRL
              Louis-DT-WRL
              @MadGyver I like that colour swing arm 🙂 good work
              • Yamboy46Y
                Yamboy46Y
                Yamboy46
                This is a interesting build. Nice one dude.
                • MadGyverM
                  MadGyverM
                  Hello,after a long time,it's a slow project due to some personal matters from time to time.
                  "Last minute" tuning to crankcases for matching,widening,angles retaining and "little" tuning to Athena cylinder/head (trasnfer port shape and sizes,exhaust port shape,size and timing,combustion chamber volume,compression)
                  • MadGyverM
                    MadGyverM
                    Wheels condition when purchased and finished
                    3
                      Fabulous stuff!
                        @MadGyver Top job bro, have you resprayed them yourself???
                        • MadGyverM
                          MadGyverM
                          Thank you all.
                          Yes almost everything is painted,machined by me,only an custom axle-spacers for the front-back wheel and a welding back of the frame tail base because of a broken bolt was done to a machine shop.
                          • MadGyverM
                            MadGyverM
                            This is the frame after the paint removal and acid treatment for the rust,then painted,before paint,cold zinc was applied to the frame for rust protection.That stage and the frame in original condition was lost in the data corruption.
                              @MadGyver Nice paint job. :thumbs_up_medium-light_skin_tone:
                                MadGyverM
                                MadGyverM
                                • MadGyverM
                                  MadGyverM
                                  Hello after a long time.
                                  I had to open the crankcases because of a faulty gearbox part (even checked I've missed it).
                                  Did some further tweaking to the cases,matched them 99+% I believe,and gave a texture to help flow and "grab" more mixture,widened a little the reed valve space and removed some metal from the low right corner for the RZ350 reed valve to be installed.
                                  • MadGyverM
                                    MadGyverM
                                    The finished DTZr,it's on the road,I am doing some runnin km's and will go to a friends dyno. 😀
                                    Passed technical inspection with "flying colors".
                                    I didn't put the 3ET headlight because it's no good for night,if you want to see and not just others to see you.
                                    PS.I will shorten a little the front fender.
                                    CalumC zarkotomZ 2 Replies Last reply
                                    3
                                    • NottsbikerN
                                      NottsbikerN
                                      Bike looks great and similar (not wheels) to my old DTR that I built years back (profile picture).
                                      I've just bought a 3ET light unit for my 200WR as I believe that they are the same so I'm gutted to hear that they are poor output but I want to go back to stock as the 125X unit I've got does come in white and therefore looks odd.
                                      Interesting that you've also gone down the 3ET swingarm route as I've got one ready to go on my 3SH build - great minds think alike! 🙂
                                        @madgyver Yeah that looks mint to be fair. Done a great job on that.
                                          zarkotomZ
                                          zarkotomZ
                                          zarkotom
                                          @madgyver Great bike mate, looks almost like a long lost cousin of my DTR!
                                          Καλησπέρα απο ελλάδα αδερφέ... Αν έχεις facebook μπες στην ομάδα 2T POWER GREECE... Nα ανεβάσεις καμία φώτο να το χαζέψουμε ακόμα παραπάνω...
