  3. Other
  4. Aprilia RS250 1999 Mugello Replica
42 Posts 5 Posters 11.8k Views
    what method should i use to paint the calipers?
    and should i rebuild the calipers or no need?
    @pedrobatista10 If you can get the parts to rebuild, then I would.
    I remember one day riding to work, the rear brake seals failed. Leaking fluid all over my wheels. Discolouring the paint work 😞
      It's a Suzuki rgv250 engine in these isn't it?
      • D DTR+NSR
        @DTR-NSR That's correct.
          @pedrobatista10 If you wish to repaint them then just give them a rub down with some wet n' dry, then respray them with some Very High Temperature paint for a good finish. If the pistons are not damaged in any way, then you could replace the seals if needs be? I would perform a full strip down, thoroughly clean everything with a pressure washer, then give the outside of the pistons a very light rub with some fine wet n' dry and ruba small amount of copper slip on the outsides only. Then rebuild with new seals if required and perhaps new brass banjo bolts & nipples. They look to be in good overall condition, so a strip, clean, re-grease and rebuild might just be enough??? 😉
          • pedrobatista10P
            pedrobatista10P
            pedrobatista10
            guys i think i will use vapour blasting services on carbs, engine cases, brembo calipers and some other parts to make it look mint condition. and price is reasonable.
            i saw some photos and i like how it looks.
            @NINJA @Calum its possible to powder coating the calipers? i want the original gold colour on them.
              #27
              @pedrobatista10 yes they can be powder coated, seek out a local firm and ask their advice.
                @Calum I thought that was the case, I'd be checking the powervalves carefully as I know on the Suzuki's there prone to failing and dropping the power valve into the cylinder, ouch!
                • pedrobatista10P
                  pedrobatista10P
                  pedrobatista10
                  @DTR-NSR you are right, that the most dangerous part on engine, if the pin get lose can damage engine pretty bad. thats why i will change it
                  @NINJA will do that. thanks 🙂
                  • pedrobatista10P
                    pedrobatista10P
                    pedrobatista10
                    hi
                    i will send my carburetors and brembo calipers to rebuild to "MHF Restoration Macclesfield Cheshire" in UK. they do amazing jobs in restauration projects.
                    anyone used this company before?
                      Can't say that I have. But I have never needed a carb being rebuilt before.
                      • pedrobatista10P
                        pedrobatista10P
                        pedrobatista10
                        Hi
                        Long time without parts, so i will update with big package from BlackFriday that arrived today
                        Brembo RCS19
                        Brembo Rear Disc's and brembo pads
                        TWM Clutch Lever
                        TYGA Rear Step kit with carbon cover's
                        Mellotti handlebars and triple clamps
                        Domino Throtle
                        i keep the same brands for this rs250 build. why change when the quality is very good 😊
                        still lots of parts to buy ...
                        hope you like it
                          Absolutely savage!
                          I literally could only afford to do this to one bike, let alone two!
                          Fair play.
                          Looking smart bud.
                          • pedrobatista10P
                            pedrobatista10P
                            pedrobatista10
                            @Calum thanks 😉
                            it hurts my wallet building this 2 bikes, but i dont regret it. with time i will finish this one too
                            and living with parents helps to save cash for my hobbies 🙂
                            next week im receiving Transmission Kit from Renthal from reputable seller in UK (TheTuningWorks)
                              @Calum thanks 😉
                              @pedrobatista10 But when they are finished and you get the joy of riding them, it all becomes worthwhile for-sure!!! 🏍 💨 💨 💨
                                @NINJA Cough Still haven't used my RS yet! 😂
                                pedrobatista10P NINJAN 2 Replies Last reply
                                  pedrobatista10P
                                  pedrobatista10P
                                  pedrobatista10
                                  @Calum wow really? How could you resist to ride it, after that awesome build? 🤔
                                    #38
                                    @Calum Next spring when the sun's out - you'll get the itch!!! 🏍 💨 💨 💨
                                      @pedrobatista10 It is not registered. Has no license plate.
                                      • pedrobatista10P
                                        pedrobatista10P
                                        pedrobatista10
                                        wrote on last edited by pedrobatista10
                                        #40
                                        hi guys, hope all of you are safe!
                                        quick update for my project
                                        received my calipers and carbs from MHF UK, they vapour blasted and pwder coated calipers and on the carbs vapour blast and ultrasonic cleaning. they look new now imo
                                        you can see the condition of the calipers in this topic to check the difference 😛
                                          Yes, they look fabulous!
