  3. DTRE
  4. The Leviathan Project
136 Posts 25 Posters 123.3k Views 4 Watching
    @Calum COOL pic. They reckon with the Aprila MX 125, if you swap the exhaust for the RS under slung pipe you get an extra 2hp, maybe the DT receives the same benefit???
    N
    N
    NosmokeNopoke
    @NINJA I had a handmade underslung pipe from Romeu on my DTR and wow it made a difference once she was jetted correctly!! Couldnt tell you BHP wise but it certainly made a huge difference, absolute flier! And as poster said, sounds THE tits!
    • pedrobatista10P
      pedrobatista10P
      pedrobatista10
      i have romeu henriques pipe too on my dtx and its amazing the sound!
        Wrap around exhausts are a compromise for clearance. This would be no good off road, but designed to be performant.
        Jetting wise, on my vhsa, it's a tad lean. Breaking up in the mid range before it comes on pipe. Compare that to the dep pipe same setup, it was far too rich. So it is definitely utilising the fuel better.
          @Calum Do you need some extra bling???
          https://www.ebay.co.uk/itm/Aluminium-brake-clutch-reservoir-cover-engraved-alloy-yamaha-logo/163643491800?hash=item2619e985d8ⓂmLM5llX4n76gdhiuwe6YFPw
            @NINJA Yeah I like that. Is that the rear reservoir cause everything else is non-standard...
            NINJAN 2 Replies Last reply
              @Calum I think that it's basically a universal cap to fit any 50mm diameter reservoir, so it can be used on either the front or rear. 😉
                @Calum Is your underslung a Romeu pipe or is it custom made???
                  @NINJA Yeah it's a Romeu pipe. Bought it years and years ago. 2012 I think. With a Jolly Moto silencer.
                    #120
                    @Calum I thought so, I was just looking it up on ebay;
                    https://www.ebay.co.uk/itm/YAMAHA-DTR-125-Stainless-Steel-Exhaust-Pipe-Hand-Made-for-DTR-DTX-E-DT125/302400217348?hash=item4668752104:g:bHIAAOSwNSxU03eA
                    I spotted this MX on the web with an RS pipe fitted to it and the dude reckons it adds 9Bhp to the 122 lump!!!
                      A good pipe will make or break a two stroke.
                      Pipes have such a varied affect.
                      I won't rule it out, although 9 is extreme!
                      You can get 9 BHP more, but the Power Curve would be like J (Nothing nothing Nothing ohh power change).
                      Or get a pipe where it's powerband is more well rounded.
                      A wrap around exhaust is a huge compromise in performance. It's designed for clearance, not performance in mind. And underslung really releases that last part of the performance, at the expense of clearance.
                      But it's a stylistic choice that not everyone wants. I like it, it suits me as I dont' do, or plan on doing, offroading.
                      • pedrobatista10P
                        pedrobatista10P
                        pedrobatista10
                        on my dtx i have romeu inox pipe too. i guess here in portugal, he is the best making them for dtr/x
                          #123
                          @Calum That's a Jollymoto pipe, which is very similar to Romeu's own version. It is a very unique look for-sure, the RS pipe tucks under pretty nicely tho, so it's not a total eyesore. This may be a future mod for my MX, along with other planned upgrades. The owner had other mods on it, here's his gibberish;
                          "my 41 bhp mx 125 its been tuned by 55cctuning.com they have dun all the dyno work all the tuning the beggest power mod was the jollymoto pipe off a rs 125 it gave it 9 bhp just from the pipe it was 26 bhp when i got it.the pipe made it 35 hp then i got 34 carb- racing piston-racing reeds-twinair air fliter-bigger jets that gave it 6 bhp its very fast for a 125 it run 14.flat at york dragway with a 4.9 0/60"
                            Highly doubt it's putting out that much power. Love to see the power
                            curve.
                              curve.
                              @Calum Yeah that would be interesting for-sure.
                                Just a note for myself in the future.
                                Front Master Cylinder 2002 RSV Mille
                                Front Forks WR250F 2003 Kayaba 46mm
                                That's the problem when you go custom, can't remember where half this stuff is from 🤣
                                  @Calum i do a similar thing if i need to remember some numbers or specs ill just send the message to my brother bit confusing though when he gets a random 47 come through in the middle of the night
                                    Meanwhile on this project...
                                    I have been enjoying the Athena kit so much I thought it would benefit from a mild port.
                                    Off to Mick (who seemingly loves to chat about smokers on company time 🤣) with the requirements.
                                    In this instance I specifically didn't want the exhaust port raised, in essence the Athena kits power deliver is precisely where I want it. But the transfers, exhaust and powervalve did want a touch up.
                                    Since the exhaust port wasn't raised I didn't need any work done to the head.
                                    New piston, rings and gaskets ordered and I will endeavour to smash this on once that arrives, PJME said they are awaiting restock towards the end of this month.
                                    All in all looks like a good job, but this is a VERY mild port for good reason. I have the RS for that screaming power delivery and I just didn't quite enjoy the peaky power of the ported 3MB once I had the RS and Cagiva.
                                      @Calum finally managed to get this fitted yesterday.
                                      Some chap on eBay was selling Titanium cylinder mounts.
                                      As well got a nice Yamaha Tuning Fork engraved YPVS cap.
                                        @Calum I like that cap. Nice and subtle unlike the coloured plastic ones.
                                          Well they had done superbly well...
                                          I knew they need doing eventually. These were 10+ years old when I bought them and this has been my trusty steed for ~10+ years, once daily then stored for 4 years now just a weekend warrior.
                                          Painless process to strip and rebuild and the kits are readily available on eBay.
                                          All cleaned, rebuilt, new oil and refitted.
                                          These are fully adjustable and I must admit, have just been on whatever setting they came with off the MX bike I bought them from. Since this is a road warrior, I've stiffened the suspension up a fair amount. I'll be interested in seeing how this now performs on the road!
                                          The last ride out I did ~70 odd miles, the handling was becoming very poor. So I'm looking forward to the next adventure on it.
