  4. Ypvs
Ypvs
25 Posts 5 Posters 2.2k Views
    jonne123
    Does the right half of the axle be in somw direction that it can be removed?
      Typically it'll be gummed up. The various carbon deposits and the heat and cooling cycles won't help neither.
      Also, the valve is of a particular shape, I think it can rotate freely 360 degrees, but ideally you want to make sure it's aligned flush with the exhaust port.
        jonne123
        So i have aligned the ypvs with drill bit. Should it be flush now?
          I don't do it that way as I find it hit and miss.
          Personally, take the exhaust off and make it flush with the port.
            jonne123
            So you align the cables when its flush and then tighten them so no slack?
              But making sure that the powervalve is in a known state. It's no good aligning the powervalve to the port if it is midway through the cycle. as it'll be off as soon as you do a power cycle.
                jonne123
                What i have to do to sure that wont happen
                  Cycle the ignition system so it does the cleaning cycle.
                    jonne123
                    What do you think which way is better? https://youtu.be/obMy0adby8Y
                      Align flush with the exhaust port.
                      Any step in the exhaust port will disrupt the flow of gases.
                      As I have already said.
                        jonne123
                        I cannot make it flush with cables
                          How odd.
                            How odd.
                            @Calum reproduction cables maybe?
                              @declan I don't know mate, it's hard to say without actually being there to do it myself.
                              • DTleeD Offline
                                DTleeD Offline
                                DTlee
                                Don’t you need to take the cables out and the black plastic part. Dont think you can do it by just adjusting the cables? Once you have the black plastic part out you can turn it by hand I think
                                  You adjust the YPVS using the cables and threads to adjust it appropriately.
                                  • DTleeD Offline
                                    DTleeD Offline
                                    DTlee
                                    Weird, I couldnt get enough adjustment just using the cables. So I took it apart and turned the power valve by hand so it was flush an put it back together and tightened the cable. Which I’m hoping has working alright. Haven’t got it quite ready to go on the road to test it yet though
                                    • DTleeD DTlee
                                      @DTlee But that doesn't make sense? How could the cables reach otherwise?
                                      • DTleeD Offline
                                        DTleeD Offline
                                        DTlee
                                        I had to flip the power valve 180 degrees, it’s not that the cables wouldn't reach but the adjustment on the screws wasn't enough to do it. Unless I majorly over complicated it for no reason?
                                        • DTleeD DTlee
                                          @DTlee yeah they doesn't make sense to me it should adjust with the cables no problem with plenty thread to spare sure your pv was in correctly?
                                          DTleeD 1 Reply Last reply
