  4. Ypvs
Ypvs
25 Posts 5 Posters 3.5k Views
    Typically it'll be gummed up. The various carbon deposits and the heat and cooling cycles won't help neither.
    Also, the valve is of a particular shape, I think it can rotate freely 360 degrees, but ideally you want to make sure it's aligned flush with the exhaust port.
      jonne123
      So i have aligned the ypvs with drill bit. Should it be flush now?
        I don't do it that way as I find it hit and miss.
        Personally, take the exhaust off and make it flush with the port.
          jonne123
          So you align the cables when its flush and then tighten them so no slack?
            But making sure that the powervalve is in a known state. It's no good aligning the powervalve to the port if it is midway through the cycle. as it'll be off as soon as you do a power cycle.
              jonne123
              What i have to do to sure that wont happen
                Cycle the ignition system so it does the cleaning cycle.
                  jonne123
                  What do you think which way is better? https://youtu.be/obMy0adby8Y
                    Align flush with the exhaust port.
                    Any step in the exhaust port will disrupt the flow of gases.
                    As I have already said.
                      jonne123
                      I cannot make it flush with cables
                        How odd.
                          How odd.
                          @Calum reproduction cables maybe?
                            @declan I don't know mate, it's hard to say without actually being there to do it myself.
                            • DTleeD
                              DTleeD
                              DTlee
                              Don’t you need to take the cables out and the black plastic part. Dont think you can do it by just adjusting the cables? Once you have the black plastic part out you can turn it by hand I think
                                You adjust the YPVS using the cables and threads to adjust it appropriately.
                                • DTleeD
                                  DTleeD
                                  DTlee
                                  Weird, I couldnt get enough adjustment just using the cables. So I took it apart and turned the power valve by hand so it was flush an put it back together and tightened the cable. Which I’m hoping has working alright. Haven’t got it quite ready to go on the road to test it yet though
                                  • DTleeD DTlee
                                    @DTlee But that doesn't make sense? How could the cables reach otherwise?
                                    • DTleeD
                                      DTleeD
                                      DTlee
                                      I had to flip the power valve 180 degrees, it’s not that the cables wouldn't reach but the adjustment on the screws wasn't enough to do it. Unless I majorly over complicated it for no reason?
                                      • DTleeD DTlee
                                        @DTlee yeah they doesn't make sense to me it should adjust with the cables no problem with plenty thread to spare sure your pv was in correctly?
                                        DTleeD 1 Reply Last reply
                                          DTleeD
                                          DTleeD
                                          DTlee
                                          @declan maybe I was making a meal out of it then. Seems to have worked though
