Ypvs
What do you think which way is better? https://youtu.be/obMy0adby8Y
Weird, I couldnt get enough adjustment just using the cables. So I took it apart and turned the power valve by hand so it was flush an put it back together and tightened the cable. Which I’m hoping has working alright. Haven’t got it quite ready to go on the road to test it yet though
I had to flip the power valve 180 degrees, it’s not that the cables wouldn't reach but the adjustment on the screws wasn't enough to do it. Unless I majorly over complicated it for no reason?
@DTlee yeah they doesn't make sense to me it should adjust with the cables no problem with plenty thread to spare sure your pv was in correctly?
Take it apart, clean and refit with a new o-ring
