  4. Carb to filter rubber
14 Posts 7 Posters 1.6k Views 1 Watching
  • S Offline
    Can you please tell me why I’ve got a hole in the side of my air box rubber? It’s obviously factory made, but it’s not obvious what it’s there for 🙂
      Yamaha Air Intake System (YAIS)
      People mistake it for a restriction and remove it. Find the bottle and refit it.
      • G Offline
        G Offline
        GeirA
        The idea of Yamaha's "Yamaha Energy Induction System" (YEIS) was developed in the early eighties to comply with the new exhaust emission standards in the US at that time.
        In theory, the idea was to conserve some of the air momentum via this box and help fill the crankcase at the next stroke. Yamaha claimed this had an effect on both fuel efficiency and power. But it was later discontinued and I can't remember that any other motorcycle brands did something similar.
        • G GeirA
          @GeirA when was it discontinued? This was ran on all DTR models right up until their very last model.
          And yes YAIS was their other mechanism from the exhaust. I don't know why I put that.
          Ultimately Yamaha is a massive company and if they didn't think it did anything then they wouldn't have wasted the money manufacturing the bottles for so long.
          declanD G 2 Replies Last reply
            @Calum I think he means other 2 strokes didn’t fit them
              @declan probably because it was patented technology. Other manufacturers didn't use YPVS. They had to make do with their own derived systems.
              There is a big difference between the RAVE system on my RS and the YPVS system on my DTR.
                @Calum nah that’s not the case many tuned 2 strokes still use the bottles they just don’t seem to come stock
                  🤷 Yeah I don't know.
                  • S Offline
                    Cheers guys.
                    Anyone of one for grabs or sale? Never seen one anywhere...
                      Cheers guys.
                      markus.wM Offline
                      markus.wM Offline
                      Yamaha DT125R Boost bottle yeis chamber 2 DTR DT125 DTR125 YPVS TZR GPR SC125
                        NottsbikerN Offline
                        NottsbikerN Offline
                        @markus-w said in Carb to filter rubber:
                        The YEIS chamber sits on the inlet manifold above the reed block
                        The chamber on the side was only fitted to the later models and I'd assume was some kind of intake silencer rather than a performance related part
                          G Offline
                          G Offline
                          GeirA
                          wrote on last edited by GeirA
                          @Calum as you know, DTR was first released in 1988 and even though YEIS has been a part of the intake system on the DTR throughout the years doesn't mean it did very much for the performance in either way. And because YEIS wasn't implemented in any newer two-stroke models from Yamaha may confirm that. YEIS might also have been more of a marketing strategy to keep two-strokes popular in a time when four-stroke engines began to take bigger market shares.
                          Yes, Yamaha could have removed it, but that cost resources and money. So why change something that probably just doesn't matter either way? Yamaha is also a company that are reluctant to change motorcycle models that still sell well, like the DTR. Yamaha YZF ThunderCat was another motorcycle that was sold for many years virtually unchanged. In Asia and South-America there are models designed in the 70s that still are produced and still sell well in those markets. They aren't even manufactured in Japan. Actually, Yamaha has a lot of factories around the world that produce the same models year after year, and models we will never see in Europe or the US. Even the design of some models is done outside Japan. I know for sure that Yamaha DTR 50 was designed and produced by MBK in France, not Japan.
                          • DartyD Offline
                            DartyD Offline
                            wrote on last edited by Darty
                            @GeirA What’s your point? lots of 2strokes in the 1980s used ‘boost bottles’ - YEIS was used on big bore IT’s and YZs from the early 1980’s.
                            It was deemed an improvement on engines that are now over 30years old in design.
                            2strokes were still being understood well into the 1990s,
                            The second YEIS bottle was added to the DTR for the 2000 model year 😂,
                            • NottsbikerN Offline
                              NottsbikerN Offline
                              Yamaha just refer to both of them as Air Chamber on the parts diagram's - I still say its not a performance item and its just a bolt on for emissions / silencing etc.
