Yamaha DT 125R 1994 project
My ported suzuki pv moped: https://www.youtube.com/watch?v=Ds1trRkr22g
So i had little worn rear tire so this happened... little backfire also. https://www.youtube.com/watch?v=GruRc--3zNA
Check out his pootube vid, then ask yourself why you asked
Sorry, did I miss your dry humour?
So basically i was just revving the hell of it for about 20 seconds went driving and felt weird. Engine stalled kickstart stuck.
So i opened the engine and there was bearing pieces over piston so rod bearing failure. There was sand in engine via bad air filter from previous owner. Also the piston was ridden about 1500km and the ring cap was 0,7mm on the top one and 0,5mm bottom one. And the needle bearing was shot. So the engine would have failed eventually. I think i know now what the werid side noise was.
https://i.imgur.com/jsw8S7K.jpg -
https://i.imgur.com/jsw8S7K.jpg@jonne123 said in Yamaha DT 125R 1994 project:
Is called seizure by heat or lack of oil. Or screaming from cold start. Or all of the above...
โThere was sand in engine via bad air filter from previous owner. โ
Bad you never checked as well though bud (the filter) bike stuff 101
The rest is lost in translation, to me.
Well it had rebuild top end and i changed the filter right away but didnยดt realise that there was sand in the intake until month ago i cleaned it. Also the engine was making weird side noise probably from crankshaft. There was oil and mixture was rich.
@jonne123
YouTube & your back tyre says otherwise!
An engine rebuild is always around the corner on a second hand bike, no matter what the previous owner says. If you do as good a job with the engine as you did with the rest of the bike, youโll end up with a good, tight bike. Just run it in on less than 90% throttle!!
Yeah... But it was like month after burnout. The engine has always made weird side noise. But it would really been sad if it happened during next summer. The bearing would failed. Also the needle bearing is totally worn and piston rings. Remember to clean your air filter!
But now plans for the project:
-Fix rust and paint some parts.
-Clean aluminium parts.
-Fix engine
-Replace worn parts.
-Sticker kit or wrap for plastic parts.
-Possible some tuning parts.
Iยดm open for suggestions!
-Fix engine
I know that the crankshaft bearing failed. But there could be something else like a bearing.
@jonne123 Yes, but WHY did the crank bearing fail?
There is no point in rebuilding it if you don't understand why it failed.
Yeah the previous owner said it had engine rebuild but im guessing he meant top end because the engine bolts were so stuck and the engine was so dirty. Going to buy wรถssner piston and connecting rod. Good main bearings and seal.
@jonne123
Wossner and forged pistons are good, but you need to get the clearance right to allow for expansion. I understand buying the best you can, but is it really necessary? If youโre rolling in ca$h ignore me!
Just donโt fall into the trap of thinking expensive is best...
With your input, this post could be even better ๐
