  4. Yamaha DT 125R 1994 project
48 Posts 7 Posters 15.6k Views 1 Watching
    jonne123
    Bought blinkers and testing the wire lenght and fitment.
    Cooland leaking need to fix that.
    Why there is 2 wires to park bulb? It works but is park always on okay?
    Dissambling horn for painting.
    Painted
      jonne123
      Also here is video of it when i bought it. I bet you haven´t seen that moped that is on my channel.
      https://www.youtube.com/watch?v=4OosJkBa6rY
        Yeah that Suzuki is bad ass!
          jonne123
          And of course easy tuning capabilities for a death trap.
          https://www.youtube.com/watch?v=RParzmhh2UU&t=0s
          We also have every summer this "PV Forum`s speeding days event"
          https://www.youtube.com/watch?v=VYENYD-84z4&t=0s
            Haha that's brilliant.
              jonne123
              New rim + sparkplug 34e.
              Still leaking without the engine running cant understand why
                jonne123
                Could someone identify what exhaust is this? https://www.tori.fi/vi/65670465.htm
                clawsC 1 Reply Last reply
                • J jonne123
                  clawsC
                  clawsC
                  claws
                  @jonne123 giannelli probably.
                    Or BigOne
                      jonne123
                      My ported suzuki pv moped: https://www.youtube.com/watch?v=Ds1trRkr22g
                        jonne123
                        So i had little worn rear tire so this happened... little backfire also. https://www.youtube.com/watch?v=GruRc--3zNA
                          jonne123
                          So i had engine failure and said what the heck i will rebuild it. and tune the bike up. Pictures coming!
                            Wow, why did the engine fail?
                              #25
                              Check out his pootube vid, then ask yourself why you asked 🤔 ...
                              Sorry, did I miss your dry humour? 🙂
                                @SpookDog no I did see the video. Still though, a little burnout never hurt anyone 🤣
                                  jonne123
                                  #27
                                  So basically i was just revving the hell of it for about 20 seconds went driving and felt weird. Engine stalled kickstart stuck.
                                  So i opened the engine and there was bearing pieces over piston so rod bearing failure. There was sand in engine via bad air filter from previous owner. Also the piston was ridden about 1500km and the ring cap was 0,7mm on the top one and 0,5mm bottom one. And the needle bearing was shot. So the engine would have failed eventually. I think i know now what the werid side noise was. 😁
                                  https://i.imgur.com/jsw8S7K.jpg
                                  https://youtu.be/GrOBDzHtQpY
                                  • J jonne123
                                    #28
                                    @jonne123 said in Yamaha DT 125R 1994 project:
                                    Is called seizure by heat or lack of oil. Or screaming from cold start. Or all of the above...
                                    “There was sand in engine via bad air filter from previous owner. “
                                    Bad you never checked as well though bud (the filter) bike stuff 101
                                    The rest is lost in translation, to me. 🙂
                                      jonne123
                                      Well it had rebuild top end and i changed the filter right away but didn´t realise that there was sand in the intake until month ago i cleaned it. Also the engine was making weird side noise probably from crankshaft. There was oil and mixture was rich.
                                        Totally! I like to burn out my back tyre though. Not my engine 😜 ...
                                        • J jonne123
                                          #31
                                          @jonne123
                                          Sorry dude! Don’t take me to heart. I’m on my 4th beer! I don’t mean to come across as patronising ...
