  3. Carburetor
  4. Air filter oil. Ram Air foam filter
9 Posts 5 Posters 1.3k Views
  • markus.wM Offline
    markus.wM Offline
    Hi all, my foam filter is a bit dry so I have order a can of filter oil but was wondering has anyone used any other type of oil just to get me going until my order arrives?
    S markus.wM Stevie WonderS 3 Replies Last reply
      @markus-w
      Engine oil, regular 4 stroke stuff...
        I just used two stroke oil :rolling_on_the_floor_laughing:
          markus.wM Offline
          markus.wM Offline
          @markus-w thank you both.
            @markus-w would have thought 4 stroke would be too thick but i guess if you wring the filter out good it would be fine
              markus.wM Offline
              markus.wM Offline
              @declan yes that makes sense thanks. I think I'll go with the 2stroke oil as I have lots here and it can't do any harm if small particles get inside the carb or bore, just wanted to check first if anyone else has used it. I will put some in a spray bottle and hopefully it will be thin enough to go through it.
                @markus-w
                The manual says to wash it out with brake or clutch cleaner (not petrol) use motor oil and wring out the excess...
                  @markus-w
                  markus.wM Offline
                  markus.wM Offline
                  @SpookDog ok thanks.
                    Stevie WonderS Offline
                    Stevie Wonder
                    @markus-w said in Air filter oil. Ram Air foam filter:
                    https://www.ebay.co.uk/itm/283683433382
                    One of my first purchases, comes with piper cross air filter cleaner and conditioner. £20 too. Bargain.
