  3. Swingarm
Swingarm
13 Posts 5 Posters 1.9k Views
    Can some post a picture of it up?
    I don't know what you're on about?
    O 1 Reply Last reply
      @calum on the main axis of the swingarm I have 2x grease nipples, one for each side, on the 88 bikes. I'll pop a pic up as soon as I can
      • O oldman
        @oldman how odd. Yeah the later ones didn't have that then.
          @calum
          There you go, not easy to see but one each side.
          Dt125r grease nipples on swingarm:
            Ah yes okay. Yeah that's pretty useful.
              @calum
              There you go
              All mine have had them except the one I am doing, cost cutting no doubt
              • T
                T
                theportingmaster
                On my 2003 dt there a 3 grease nipples, 1 on swinging arm and 2
                on the linkage bolts.
                • T theportingmaster
                  some people add those grease nipples
                    @declan
                    I would of done if I’d had any decent taps when I was rebuilding my swing arm. Mines an 88 (allegedly 🙂 things change with 15 registered previous owners) and I don’t have any fitted. It’s a pretty shitty cost save IMO. The bearings were rusty when I stripped it down. Being able to top up the grease would of extended the seals life, which would of prevented water getting into the needle bearings...
                    False economy @ the buyers expense! The nipples are pennies and drilling and tapping 2 holes can’t be that expensive!...
                      I can't see it being a cost thing.
                      My DTR's swingarm bearings were fine. And besides the point, it's not a big job to pull the swingarm bolt and regrease.
