  3. Swingarm
Swingarm
13 Posts 5 Posters 973 Views
  • O Offline
    O Offline
    On both my 1988 dts they have grease nipples on the swingarm, just changing the bearings on another and no grease nipples?. Were they omitted from later bikes?
      On the underside with the linkages? They are on my 2005 DTRE. But none on the swingarm itself
      • O oldman
        @oldman
        I have no idea why, but they don’t have any on later swing arms. Also I think some models have one on one side only, why again, I don’t know! They seem like a good idea...
          Can some post a picture of it up?
          I don't know what you're on about?
          O 1 Reply Last reply
            O Offline
            O Offline
            @calum on the main axis of the swingarm I have 2x grease nipples, one for each side, on the 88 bikes. I'll pop a pic up as soon as I can
            • O oldman
              @oldman how odd. Yeah the later ones didn't have that then.
                O Offline
                O Offline
                @calum
                There you go, not easy to see but one each side.
                Dt125r grease nipples on swingarm:
                  Ah yes okay. Yeah that's pretty useful.
                    O Offline
                    O Offline
                    @calum
                    There you go
                    All mine have had them except the one I am doing, cost cutting no doubt
                    • T Offline
                      T Offline
                      theportingmaster
                      On my 2003 dt there a 3 grease nipples, 1 on swinging arm and 2
                      on the linkage bolts.
                      • T theportingmaster
                        some people add those grease nipples
                          @declan
                          I would of done if I’d had any decent taps when I was rebuilding my swing arm. Mines an 88 (allegedly 🙂 things change with 15 registered previous owners) and I don’t have any fitted. It’s a pretty shitty cost save IMO. The bearings were rusty when I stripped it down. Being able to top up the grease would of extended the seals life, which would of prevented water getting into the needle bearings...
                          False economy @ the buyers expense! The nipples are pennies and drilling and tapping 2 holes can’t be that expensive!...
                            I can't see it being a cost thing.
                            My DTR's swingarm bearings were fine. And besides the point, it's not a big job to pull the swingarm bolt and regrease.
