  3. DTRE
  4. Yamaha dt125 re restore
18 Posts 5 Posters 2.9k Views
  • K Offline
    K Offline
    kevb1967
    Yamaha dt125 re restore [0_1618075482257_s-l1600.jpg](Uploading 100%)
    • K kevb1967
      @kevb1967
      Wot iz das?...
      K 1 Reply Last reply
        @kevb1967
        Wot iz das?...
        K Offline
        K Offline
        kevb1967
        cant up load photos says to large even when i make them smaller ?
        • K kevb1967
          NINJAN Offline
          NINJAN Offline
          @kevb1967 I had the same problem, @Calum may know why?
            @ninja this website doesn't support image hosting. Image hosting is expensive so I rely on third psrty file hosting.
              NINJAN Offline
              NINJAN Offline
              @calum OK Good-to-know, I'll use imgur in future. 😉
              • K Offline
                K Offline
                kevb1967
                before photos
                https://imgshare.io/image/s-l1600.pMUQGj
                https://imgshare.io/image/s-l1600-5.pMUtwS
                https://imgshare.io/image/s-l1600-2.pMUDyK
                https://imgshare.io/image/s-l1600-6.pMUF08
                https://imgshare.io/image/s-l1600-9.pMUVfw
                  @kevb1967 yeah wow, that could do with a freshen up! Looking forward to seeing more.
                  • K Offline
                    K Offline
                    kevb1967
                    bought it off eBay with 2 boxes of parts and a spare engine has been in a garage for 11 years as exhaust was coked up and it melted the battery compartment so it was partly dismantled
                    https://imgshare.io/image/s-l1600-8.pMknLO
                    https://imgshare.io/image/s-l1600-7.pMk72Q
                    water pump broken
                    barrel exhaust studs striped
                    clutch cable broken
                    power vale seized solid
                    rear break caliper seized
                    just to start with
                    • K kevb1967
                      water pump broken
                      clutch cable broken
                      just to start with
                      K Offline
                      K Offline
                      kevb1967
                      after a deep clean and de coke of top end ,has std piston with no ware signs at all power valve de coked and new seals fitted new stainless exhaust threads new dep front pipe rear cleaned new battery compartment and new battery, new water pump kit and new drive and gear oil seals
                      https://imgshare.io/image/bdzf9050.pMu79K
                      • K kevb1967
                        K Offline
                        K Offline
                        kevb1967
                        replacement plastics fitted and graphics all new oil lubricant's
                        power vale lined up ,oil pump set up was way too high .carb cleaned and up jetted to 230 from 210 new front and back sprockets ,swing arm resprayed on bike mot passed advisory on disks ,does 80 mph instantly
                        so quick .question is the the RE one of the quickest dt125s as it pees on my dtr 2002
                        https://imgshare.io/image/img-4735.pMVR47
                        https://imgshare.io/image/img-4732.pMV3ng
                        new and old
                        https://imgshare.io/image/img-4739.pMVWx6
                        NINJAN S 2 Replies Last reply
                        • K kevb1967
                          new and old
                          NINJAN Offline
                          NINJAN Offline
                          @kevb1967 Sweet looking bikes there bud. 👍
                            Yeah wow, that's quite a transformation. Looking great!
                            • K kevb1967
                              new and old
                              @kevb1967
                              That’s a very healthy looking transmutation, for sure!...
                              You can still post pics here, once you’ve hosted them:
                              How much was this dreamboat from fleabay, if you don’t mind me asking?...
                                @kevb1967
                                K Offline
                                K Offline
                                kevb1967
                                @spookdog
                                it was £1000 on eBay and spent £700 on all parts inc exhaust and a new set of tyers
                                • K kevb1967
                                  @spookdog
                                  @kevb1967
                                  That’s a bargain, it looks great. Most people are scared to take the gamble and get their hands dirty. It’s the best way to learn if you’ve got no one to teach you though. Even if you had to rebuild the engine it came in at a good price...
                                  • K Offline
                                    K Offline
                                    kevb1967
                                    does a Y-1 barrel have better performance than a Y-2 Barrel with a Y-1 head ?
                                    • K kevb1967
                                      @kevb1967 I've heard that the y1 is the highest compression head but I'm not sure on that I tried researching but didn't find anything
