  3. DTRE
  4. Yamaha dt125 re restore
18 Posts 5 Posters 4.9k Views
    @kevb1967
    Wot iz das?...
    K
    K
    kevb1967
    cant up load photos says to large even when i make them smaller ?
    • K kevb1967
      @kevb1967 I had the same problem, @Calum may know why?
        @ninja this website doesn't support image hosting. Image hosting is expensive so I rely on third psrty file hosting.
          @calum OK Good-to-know, I'll use imgur in future. 😉
          • K
            K
            kevb1967
            before photos
            https://imgshare.io/image/s-l1600.pMUQGj
            https://imgshare.io/image/s-l1600-5.pMUtwS
            https://imgshare.io/image/s-l1600-2.pMUDyK
            https://imgshare.io/image/s-l1600-6.pMUF08
            https://imgshare.io/image/s-l1600-9.pMUVfw
              @kevb1967 yeah wow, that could do with a freshen up! Looking forward to seeing more.
              • K
                K
                kevb1967
                bought it off eBay with 2 boxes of parts and a spare engine has been in a garage for 11 years as exhaust was coked up and it melted the battery compartment so it was partly dismantled
                https://imgshare.io/image/s-l1600-8.pMknLO
                https://imgshare.io/image/s-l1600-7.pMk72Q
                water pump broken
                barrel exhaust studs striped
                clutch cable broken
                power vale seized solid
                rear break caliper seized
                just to start with
                K 1 Reply Last reply
                • K kevb1967
                  water pump broken
                  clutch cable broken
                  just to start with
                  K
                  K
                  kevb1967
                  after a deep clean and de coke of top end ,has std piston with no ware signs at all power valve de coked and new seals fitted new stainless exhaust threads new dep front pipe rear cleaned new battery compartment and new battery, new water pump kit and new drive and gear oil seals
                  https://imgshare.io/image/bdzf9050.pMu79K
                  • K kevb1967
                    K
                    K
                    kevb1967
                    replacement plastics fitted and graphics all new oil lubricant's
                    power vale lined up ,oil pump set up was way too high .carb cleaned and up jetted to 230 from 210 new front and back sprockets ,swing arm resprayed on bike mot passed advisory on disks ,does 80 mph instantly
                    so quick .question is the the RE one of the quickest dt125s as it pees on my dtr 2002
                    https://imgshare.io/image/img-4735.pMVR47
                    https://imgshare.io/image/img-4732.pMV3ng
                    new and old
                    https://imgshare.io/image/img-4739.pMVWx6
                    NINJAN S 2 Replies Last reply
                    • K kevb1967
                      new and old
                      @kevb1967 Sweet looking bikes there bud. 👍
                        Yeah wow, that's quite a transformation. Looking great!
                        • K kevb1967
                          new and old
                          @kevb1967
                          That’s a very healthy looking transmutation, for sure!...
                          You can still post pics here, once you’ve hosted them:
                          How much was this dreamboat from fleabay, if you don’t mind me asking?...
                            @kevb1967
                            K
                            K
                            kevb1967
                            @spookdog
                            it was £1000 on eBay and spent £700 on all parts inc exhaust and a new set of tyers
                            • K kevb1967
                              @spookdog
                              @kevb1967
                              That’s a bargain, it looks great. Most people are scared to take the gamble and get their hands dirty. It’s the best way to learn if you’ve got no one to teach you though. Even if you had to rebuild the engine it came in at a good price...
                              • K
                                K
                                kevb1967
                                does a Y-1 barrel have better performance than a Y-2 Barrel with a Y-1 head ?
                                • K kevb1967
                                  @kevb1967 I've heard that the y1 is the highest compression head but I'm not sure on that I tried researching but didn't find anything
