  4. My DT125 80s Yz style DT200 build one to watch!
233 Posts 17 Posters 129.0k Views 3 Watching
  • M
    M
    mhbikesnbits
    Happy new everyone and all the best to all!
    not had chance do any work on my dt recently unfortunately but hopefully this is the year to get things done on a plus just found this what I think would look ace on the project
    • M
      M
      mhbikesnbits
      Well been a while since Iโ€™ve posted on this article, i just want to say the project is alive and well Iโ€™m making some progression finally. I blame a pregnancy and a pandemic for the delay ๐Ÿ˜‚
      Forget how I post picture on here will update some soon
      S CalumC 2 Replies Last reply
      • M mhbikesnbits
        @mhbikesnbits
        Sweet, Iโ€™ve not seen your project before. Some really nice attention to details ๐Ÿ‘
        Please, keep on keeping on ๐Ÿพ ...
        M 1 Reply Last reply
        • M mhbikesnbits
          @mhbikesnbits Yes wow blast from the past. Hard to think your last post was pre-pandemic. It's hard to even remember what life was like back then ๐Ÿ˜ž
            @mhbikesnbits
            M
            M
            mhbikesnbits
            @SpookDog tar buddy Hopefully a lot more of it come
              M
              M
              mhbikesnbits
              @Calum I know Iโ€™ve really been slacking I got everything back out the other day to carry on with it had to refresh my mind of whatโ€™s, what ๐Ÿ˜… itโ€™s not so bad when you first do it but 2 years later and youโ€™ve not really looked at it you forget things ๐Ÿ˜‚
              • M
                M
                mhbikesnbits
                #131
                Update 2022
                Iโ€™ve dug everything back out and got my head back around the project. The excitement to build the bike is Back but have a while to go yet. I started out by tapping out the holes on the parts that had been powder coated.
                • M
                  M
                  mhbikesnbits
                  #132
                  • M
                    M
                    mhbikesnbits
                    #133
                    Needed to get the engine rebuild under way so I can install the engine onto the frame of the bike to get some weight behind the project.
                    One of the only issues with the engine components other than the the usual wear on the bearings and seals was the play on the clutch basket.
                    So I did some research and found out you could redo the rubber bushes in the basket with RD250 bushes and rivets.
                    they sold them on yambits so I got the good old grinder on the old rivets flatten them with a sanding wheel and knocked them through
                    installed the new bushes and put it back together the play in the basket was like it would be straight out the factory.
                    Apologies but I must have forgot to take a picture of the finished basket.
                    • M
                      M
                      mhbikesnbits
                      #134
                      Had a little play with frame and put on a couple of bits, pressed in the races for the tapered roller bearings for the steering stem.
                      Love how the black contrasts with the red.
                      Also placed some bolts for the engine in position ready for the engine.
                      • M mhbikesnbits
                        Something about putting pristine bits back together. Itโ€™s like unwrapping a Christmas pressie backwards!
                        I had a similar situation with an old Audi project that I left for a year, I couldnโ€™t remember what bolts to use to put certain bits where! I had to relearn something that I used to know like the back of my hand!...
                          M
                          M
                          mhbikesnbits
                          @SpookDog oh yes you got that right it is very satisfying,Iโ€™m lucky in the respect thatโ€™s itโ€™s only a two stroke bike and not a Audi with ten times the amount of bits lol
                          • M mhbikesnbits
                            @mhbikesnbits
                            It was only an old Audi 90 10v that I went OCD on. I put a gas flowed head on it with a fat cam and lowered it. Some horrible little crackhead weighted it in when I got made homeless and wasnโ€™t around, back when the price of scrap went crazy (2010?)
                            Shtuff happens! ๐Ÿคจ ...
                            • M
                              M
                              mhbikesnbits
                              #138
                              Pretty much got the engine built just need do some finishing touches on it and order couple of other bits I used high quality bearings and seals and all genuine Yamaha gaskets including the head gasket.
                              Bore was in good condition I used a 68mm wosner piston To replace the old one
                              Thinking of putting it on the frame with no oil all in as Iโ€™m thinking of setting the clutch up all In one go once the clutch perch and cable is installed with the clutch having 3 places to to adjust it
                              I alt text
                              • M mhbikesnbits
                                I alt text
                                @mhbikesnbits looking real nice mate this going to be a quality build. I'm liking the black powder coat on all the engine parts. 68mm piston you say, would that be 200cc? Or even I'm thinking 200cc oversize?
                                  M
                                  M
                                  mhbikesnbits
                                  @markus-w cheers pal I hope itโ€™s going to look quality the money Iโ€™ve spent so far ๐Ÿ˜‚, it is a 200 e engine yes unsure what the stock size from the factory is tbh or if itโ€™s been bored out or anything
                                  markus.wM 2 Replies Last reply
                                    @mhbikesnbits
                                    M
                                    M
                                    mhbikesnbits
                                    @SpookDog what a shame bet you were gutted when you found it was gone
                                    • M mhbikesnbits
                                      @mhbikesnbits I think standard is 66mm.
                                        M
                                        M
                                        mhbikesnbits
                                        @markus-w canโ€™t wait kick it in tbh see what the engine can do
                                        • M mhbikesnbits
                                          @mhbikesnbits I've just done the maths on it. A standard 200cc barrel is actually 195cc (65.98mm piston) a 68mm bore would make it 207cc so a difference of 12cc. Should be quite noticeable.
