  4. My DT125 80s Yz style DT200 build one to watch!
233 Posts 17 Posters 108.5k Views 3 Watching
    @mhbikesnbits Yes wow blast from the past. Hard to think your last post was pre-pandemic. It's hard to even remember what life was like back then 😞
    M Offline
    M Offline
    mhbikesnbits
    @Calum I know I’ve really been slacking I got everything back out the other day to carry on with it had to refresh my mind of what’s, what 😅 it’s not so bad when you first do it but 2 years later and you’ve not really looked at it you forget things 😂
    • M Offline
      M Offline
      mhbikesnbits
      #131
      Update 2022
      I’ve dug everything back out and got my head back around the project. The excitement to build the bike is Back but have a while to go yet. I started out by tapping out the holes on the parts that had been powder coated.
      • M Offline
        M Offline
        mhbikesnbits
        #132
        • M Offline
          M Offline
          mhbikesnbits
          #133
          Needed to get the engine rebuild under way so I can install the engine onto the frame of the bike to get some weight behind the project.
          One of the only issues with the engine components other than the the usual wear on the bearings and seals was the play on the clutch basket.
          So I did some research and found out you could redo the rubber bushes in the basket with RD250 bushes and rivets.
          they sold them on yambits so I got the good old grinder on the old rivets flatten them with a sanding wheel and knocked them through
          installed the new bushes and put it back together the play in the basket was like it would be straight out the factory.
          Apologies but I must have forgot to take a picture of the finished basket.
          • M Offline
            M Offline
            mhbikesnbits
            #134
            Had a little play with frame and put on a couple of bits, pressed in the races for the tapered roller bearings for the steering stem.
            Love how the black contrasts with the red.
            Also placed some bolts for the engine in position ready for the engine.
            • M mhbikesnbits
              Something about putting pristine bits back together. It’s like unwrapping a Christmas pressie backwards!
              I had a similar situation with an old Audi project that I left for a year, I couldn’t remember what bolts to use to put certain bits where! I had to relearn something that I used to know like the back of my hand!...
              M 1 Reply Last reply
                M Offline
                M Offline
                mhbikesnbits
                @SpookDog oh yes you got that right it is very satisfying,I’m lucky in the respect that’s it’s only a two stroke bike and not a Audi with ten times the amount of bits lol
                • M mhbikesnbits
                  @mhbikesnbits
                  It was only an old Audi 90 10v that I went OCD on. I put a gas flowed head on it with a fat cam and lowered it. Some horrible little crackhead weighted it in when I got made homeless and wasn’t around, back when the price of scrap went crazy (2010?)
                  Shtuff happens! 🤨 ...
                  • M Offline
                    M Offline
                    mhbikesnbits
                    #138
                    Pretty much got the engine built just need do some finishing touches on it and order couple of other bits I used high quality bearings and seals and all genuine Yamaha gaskets including the head gasket.
                    Bore was in good condition I used a 68mm wosner piston To replace the old one
                    Thinking of putting it on the frame with no oil all in as I’m thinking of setting the clutch up all In one go once the clutch perch and cable is installed with the clutch having 3 places to to adjust it
                    I alt text
                    • M mhbikesnbits
                      I alt text
                      markus.wM Offline
                      markus.wM Offline
                      @mhbikesnbits looking real nice mate this going to be a quality build. I'm liking the black powder coat on all the engine parts. 68mm piston you say, would that be 200cc? Or even I'm thinking 200cc oversize?
                        M Offline
                        M Offline
                        mhbikesnbits
                        @markus-w cheers pal I hope it’s going to look quality the money I’ve spent so far 😂, it is a 200 e engine yes unsure what the stock size from the factory is tbh or if it’s been bored out or anything
                        markus.wM 2 Replies Last reply
                          @mhbikesnbits
                          M Offline
                          M Offline
                          mhbikesnbits
                          @SpookDog what a shame bet you were gutted when you found it was gone
                          • M mhbikesnbits
                            markus.wM Offline
                            markus.wM Offline
                            @mhbikesnbits I think standard is 66mm.
                              M Offline
                              M Offline
                              mhbikesnbits
                              @markus-w can’t wait kick it in tbh see what the engine can do
                              • M mhbikesnbits
                                markus.wM Offline
                                markus.wM Offline
                                @mhbikesnbits I've just done the maths on it. A standard 200cc barrel is actually 195cc (65.98mm piston) a 68mm bore would make it 207cc so a difference of 12cc. Should be quite noticeable.
                                  M Offline
                                  M Offline
                                  mhbikesnbits
                                  @markus-w you’ve got be excited now 😂
                                  • M Offline
                                    M Offline
                                    mhbikesnbits
                                    This gets the rattle can treatment it’s only for holding a pipe 😂
                                    Bit sloppy tbh compared to other things but going to go with a silver paint, may get one later down the Line powder coated, just want to get that engine in the frame asap
                                    • M Offline
                                      M Offline
                                      mhbikesnbits
                                      #147
                                      When we had a nice bout of sun the other day I sat in the garden, and started the lovely job of polishing the lower triple clamp.
                                      Pictures don’t really show the finish very good looks far better in person
                                      I started with 200 wet and dry and worked my way up to 1000 and finished with a hand polish of some mothers and mag.
                                      The top of the clamp is black powder coated
                                      Once the engines dropped in I can get the clamps in because the weight of them will probably drag the frame over now.
                                      My next task will be probably getting all the handle bars in the and switch gear. I’m going with some pro taper gear for the handle bars.
                                      • M mhbikesnbits
                                        #148
                                        @mhbikesnbits
                                        It definitely warrants better treatment! 😜
                                        Poor things always seem to corrode under the pipe, before the clamp...
                                        But yeah! Bung it on!!...
                                        PS. You gonna lacquer the bottom yoke?...
                                          @mhbikesnbits
                                          M Offline
                                          M Offline
                                          mhbikesnbits
                                          @SpookDog now I’m thinking make one on the cnc machine would look pretty bad ass
