  3. Suspension
  4. Progressive fork springs?
22 Posts 6 Posters 9.2k Views
    Well they are 505mm x 34mm but I can’t find anything matching online. I can’t find any kind of Nm rating either. I really need some help with this...
    There have to be loads of viable springs out there from other bikes, with various Nm ratings, both progressive and linear...
    @SpookDog What was the matter with these?
    https://www.ebay.co.uk/itm/153500752804
      Until I know for definite that the 2004>RE has 505mm springs I can’t be sure about them...
      Early Dtr’s had shorter springs than the later ones, apparently...
        @SpookDog But springs compress...
        Can you not just email then and ask?
        I remember the DTR springs are woeful, so this would most likely be an upgrade.
          I actually didn’t think to contact them 🥴
          Waiting on a fleabay reply now. I asked about length & width and rating...
            @SpookDog According to Haynes:
            3DB1 ('88 round slide carb model) spring free length 478mm, service limit 473mm
            3RN1 ('89 onward) spring free length 503mm, service limit 468mm
            No mention of forks in the separate chapter for the '97 onwards DTR and DTX so I can only assume the springs are identical to 3RN1 (although I'd be interested if this is the case particularly regarding the DTX)
              @SpookDog And according to fowlers the springs between the two models are the same.
              https://www.fowlersparts.co.uk/parts/4189524/dt125re-1d02-2005-030-a/front-fork
              https://www.fowlersparts.co.uk/parts/4159458/dt125r-3rme-1999-060-a/front-fork
              SPRING, FRONT FORK
              3BN-23141-01
                markus.wM Offline
                markus.wM Offline
                @HOTSHOT-III I believe the DTX has shorter stiffer forks.
                  SPRING, FRONT FORK
                  3BN-23141-01
                  markus.wM Offline
                  markus.wM Offline
                  @Calum yes they are identical. Just the 1988 early model are different as are the DTX. R and RE are the same.
                    That’s a typo for the 503mm spring wear limit, it’s supposed to be 499mm. Hell of a wear limit otherwise!.
                    I read somewhere that dtx springs are 515mm and progressive as standard. Probably the same as TZR springs if the info was right...
                    Got a reply from fleabay: not in UK stock, 40-45 day order wait. Springs are 515mm x 3.9mm and are rated for 65-110kg weight riders...
                    Sounds perfect, just have to trim the spring spacers by 12mm. Shame about the wait!...
                      Cheers for the info guys, it all helps!...
                      Ordered some springs, just in it for the long wait now 🙄
                      If anyone has any fork bottoms, or whole forks, please let me know. I don’t have time to powder coat mine when I rebuild them...
                      MadGyverM 1 Reply Last reply
                        MadGyverM Offline
                        MadGyverM Offline
                        DT200R springs are 548mm.Have them in mine with the air adjust cap's.
                        • MadGyverM MadGyver
                          @MadGyver
                          What bike do you have them fitted in?...
                          PS thank you for the info!...
                            @MadGyver
                            MadGyverM Offline
                            MadGyverM Offline
                            @SpookDog In my DT125.
                              @MadGyver
                              Did you just delete the spacers completely? Any noticeable improvement? Also are the springs linear or progressive?...
                              Cheers bud!...
                                @MadGyver
                                Cheers bud!...
                                MadGyverM Offline
                                MadGyverM Offline
                                @SpookDog said in Progressive fork springs?:
                                @MadGyver
                                Cheers bud!...
                                Didn't remove anything as memory serves.I had 2 forks,one DT125 and later one DT200,I had purchased every part to rebuild the 125 before having the 200.Compared everything and found to be the same except the springs.So I used the springs and the air adjust caps from the 200 forks.
                                They don't bottom easy as far I tested them and seem better for the SM style than the 125 springs,but soft to go trail ride.
