1.1k Posts 26 Posters 758.7k Views
    @markus-w
    ![alt text](image url)
    Cheers bud, I’ll keep that in mind till ‘pay day’ 🙂 …
    Hotshot! I agree with the jap Mitaka piston. It’s good stuff. I used my original one that got its crown eaten into to put my engine back together, along with the barrel that the pin ‘walked’ out of! It’s not ideal but it’ll keep me mobile till I get a couple of barrels of to PJME for rebored 🙂 bike is running really sweet with the mismatched pair as well!!…
    Back together 11.30 last night!…
    Just did a 40 mile shake down ride and it was well perky 🙂 even though I’m not going above 5~6K…
    #462
    I really am impressed with Henrique Romeau’s workmanship & design…
    I found a 22mm stainless steel P clip on fleabay for a few quid…
    Fits a treat and rubber mounted to counter vibration…
    Looks the part as well…
    I drilled out the mount hole on the pipe to 15mm to take a rubber mount, formerly used as a radiator mount on the Dtr…
    The reason for the rubber mounting is that stainless steel is a very brittle metal with non of the elasticity of softer steel. If mounted to tight and subjected to vibration it can crack quite easily…
    PS this is what happens when you ride around on salty roads! If I had access to a jet wash I’d rinse it down every chance I had! Salt kills almost as many 2 strokes as boyracers!! ☠️😛 …
      #463
      Speedo drive unit for the sr/whatever arrived at my sisters today. First impression looks good. I won’t be sure till i compare the two side by side. The oil seals are the same size, the ring drives are Less than 0.5 mm bigger on the new one. The only real difference I can tell is the teeth of the gears are different /// on one & \\ on the other…
      I’m gonna try fitting it later on, but for now it looks promising that the casing @ least will be usable. If not the whole thing…
        #464
        It fits but doesn’t work. I didn’t realise that the gears slant would affect the rotation. I’m guessing the speedo drive is fitted on the left side. Shame because it’s identical but runs backwards! but back to square one. I’ll fit my gears into the good case…
        It makes me wonder if some of the XT ones are a straight fit…
          Yep, I couldn’t get a decent pic of it but the top ring location pin has just ‘disappeared’ off flush with the piston. Weird having two fail in a row so soon. The top ring was literally spinning around in the groove. I’m amazed that an end didn’t tangle with a transfer port…
          @SpookDog The genuine Yamaha pistons have always been prone to ring pegs getting out and walking on the DTR, TZR125 and TZR/TDR250. Back in the 90s when having a rebore, we would demand Japanese Mitaka piston kits by name as they were better. Not tried any of the Wossner etc. ones available these days but Mitaka always did the job for me and I think PJME sell a lot of them.
          #465
          Have you drilled out an aluminium drive or plastic only? I’m wondering whether to try the back then drift out the pin or drill the pin out itself? I’m guessing it’s from the back…
          Again: if you know how to look up registrations and can find out what colour my bike was originally, I would really luv to know 🙂 …
          HOTSHOT IIIH markus.wM 2 Replies Last reply
            #466
            @SpookDog I looked up your 3DB - 001369 number and your bike is definitely an '88 round slide carb early bike, but it gives all three colours (white/red, black/red and endurance blue) as options.
            I've only ever repaired the plastic speedo drives. I think you could theoretically drill into an alloy one from the back and tap out the roll pin, but you'd probably need a fair bit of heat/PlusGas as the steel pin will be seized in to the alloy body. Or if you have a pillar drill and a means of firmly attaching the drive to the bed at exactly 90 degrees to the drill bit, you could drill directly into the pin with say a 1mm drill bit, then slowly increase the bit size and just get rid of it that way before choosing a slightly bigger split pin to reassemble it. TBH though it seems a shame to bastardize that SR125 drive as they're classics as well. So I'd stick it back on eBay and someone somewhere will buy it off you.
            Are you doing all this online stuff on a smartphone? Because a screen the size of a fag packet can make life very difficult. I have a smartphone but I'm old and crotchety as well, and I hate the things. Get a reconditioned PC for cheap, or use one at the library and you can have loads of windows open at once and look around all over the world for the best deal. And get on Facebook as well, I know I've said this before but there are a fair few lads on there who buy and sell DTR bits all the time, you could have an actual DTR unit in your hand by this time next week.
              #467
              @SpookDog as @HOTSHOT-III says. The Facebook groups are a really good place for getting parts and with much better prices than eBay. I myself was always anti Facebook but I gave in about 3 years ago and joined up for the sole purpose of joining the DT groups. Haven't got my picture on there. But as I said there's a Speedo drive for sale there for £40 including postage. If you want I can message the guy and try get a phone number for you?
              Also if you send an email to customersupport@yamahamotor.co.uk and tell them you have one of their bikes and you would like to get it back to original they will give you all the information you need. I did this when I got mine and received about 6 separate emails back from them. Even sent me a wiring diagram. Really couldn't fault their service. Give them the reg and vin.
              S 2 Replies Last reply
                @markus-w
                Cheers for that, I’ll try it. Would be really sweet if it was originally blue 🙂 …
                Yeah I’m on a mobile!
                  @markus-w
                  Bud! Sorry I kinda forgot about this! 101 other problems caused by salt & winter~neglect & being broke! If you can get me a number (preferably 🙂 an email? I’m not really a ‘people person’ if you haven’t guessed already! 🥴) that would be sweetAF…
                  markus.wM 3 Replies Last reply
                    @markus-w
                    @SpookDog no worries bud. I'm the same, in the way that I really don't like talking on the phone. I'll message them though it was a while ago now but they are always coming up for sale. I'll get back to you on it so remember to check back in. 👍
                      @markus-w
                      @SpookDog he just got back to me bud. Shaunallen634@gmail.com £40 posted from Swansea.
                        @markus-w
                        @SpookDog if you want to let me know when you've emailed him I'll let him know to make sure he checks his spam etc.
                          #473
                          @markus-w
                          Cheers bud, I will…
                          Sorry, I’m a bit pissed at the moment. I’ve developed another top end malevolence that I’m not even going to go into. I’m trying to suss out getting PJME to rebore a couple barrels for me. Priorities, and waiting to get some monies…
                            @markus-w
                            Cheers bud, I will…
                            @SpookDog no worries bud. Hope you get it sorted. You've had some problems with that bike but you do some big miles though.
                              @markus-w
                              Cheers bud. My top end is getting noisy again. I’m really starting to believe my conrod may be a bit bent (20,000 miles of misfires may be the culprit!) the last two pistons had eaten the locator pins, but the last piston had a mm of slack on the stator side of the gudgeon pin (where the curclip lives) you could literally rattle it around!!..
                              I’m gonna remove the stator cover and wobble the stator about and check for piston slap/rattle that wasn’t there a week ago. It’s not a good barrel and piston (cobbled from two different failures) but it was better than it sounds now…
                              I’m just packing up 2 barrels for reboring at PJME. I just need a couple main bearings and things to build an new bottom end with a good crank I got a while ago. Hopefully then it should be as it was made to be 🥴
                                @markus-w
                                #476
                                I can’t believe I’ve got water in my carb again! This time not on reserve either! Bikes stored under cover as well! I’m going to go back to premium petrol because it supposedly has no ethanol in it? Which I believe attracts water?…
                                I’ve also got a different fuel tap coming from off of a ybr, it has a large clear removable filter bowl under it that I’m hoping will act as a water trap. If it fits!…
                                I’ve never had problems with contamination like this before, ever…
                                On a brighter note, my main bearings have turned up, £35 for a pair of Koyos. I also have all the bearings ordered for the gearbox (Koyo again) apart from the two needle/roller bearings that I can’t find info on yet…
                                  @SpookDog PJME sell the gearbox needle roller bearing, only available genuine Yamaha but they always keep them in stock. Definitely run it on E5
                                    E5?…
                                      E5?…
                                      @SpookDog Instead of E10 fuel.
                                      I just run mine on VPower, but that's because it's tuned and I odn't want it detonating.
                                        @SpookDog I've always used Texaco super unleaded. Lots of Texaco stations near me, I never use super market fuel. Premium is 10% ethanol and super is 5% but even long before the change of ethanol I used it as it's a better quality cleaner fuel and what you lose on the 10p per litre extra cost you gain back on the extra miles per litre/gallon.
                                          Does anyone have an idea on how much it costs to get a wheel rebuilt/respoked? Just the labour? Has anyone had any done?…
