  4. Ignition key replacment
54 Posts 4 Posters 11.3k Views
  • E Offline
    E Offline
    erion
    wrote on last edited by erion
    Hello , first post here
    My dad had a dt 125 r since i was born but one time he lost the key to it so he broke the key thing and he replaced it with a 4wire one wich is for little bikes i think just so he could get the power valve to work maybe .
    But now i ordered a key for it but the key has a jack with 3cables and a seperate cable and my bike has a 5cable jack and i was wondering if i could make it work somehow by cutting the cables and connecting them with electrical tape
    But i don't know the year of my bike and i can't seem to find something about it maybe someone can help me find the year of the bike
    I would be thankfull for any type of help
    • E erion
      @erion
      How old are you?
        I would get the wiring diagram for your model year and for the ignition switch you bought. Ultimately I am sure it can be adapted to work, although I am not sure if taping the cables is really what you want. It will just come loose.
        The connector block can just be disassembled and then reassembled once you have identified which cable goes where.
        E 1 Reply Last reply
          E Offline
          E Offline
          erion
          @Calum i fixed it i cut the cables from the jack and conected them with tape 2 blue cables were left but it works idk what they are for ,anyway can you tell me where to llok for info on my bike to identify it exept the little white letter on the frame between the forks
          • S Offline
            Should be stamped into the frames headstock. Throttle side. Try the engine number as well. Should be on the gear change side, above the front sprocket. I’m going to hazard a guess that there’s no number plate?…
            • E erion
              markus.wM Offline
              markus.wM Offline
              @erion to identify the year you need to read the frame number on the headstock. If you care to tell me the first few digits I may be able to help you with it. Should begin 3DB123 Or 3MD123 Or 4BL123? I'm guessing you don't know the reg? There's a company on Facebook called vin to reg/ reg to vin. They will find the reg from your frame number for £5 which you only pay if they find it.
                E Offline
                E Offline
                erion
                @SpookDog yeah its a switzerland import i think because they got it in swiss in 2006 i think and we are the 2nd owners of the bike but the documentations are lost and we didnt register it in kosovo so yeah
                  E Offline
                  E Offline
                  erion
                  @markus-w in the head stock is a number pressed on the frame it's 4dk-006706
                  And there is a number in the cylinder block wich may be the engine number and its 3mb00
                  E S 2 Replies Last reply
                  • E erion
                    E Offline
                    E Offline
                    erion
                    @erion and another one on the trans on the left side but im not sure where the engine number should be
                    • E erion
                      @erion
                      Don’t want the cylinder barrel/block. You want the number above the front sprocket, just below/behind the carburettor…
                      S E 2 Replies Last reply
                        @erion
                        Only thing I could find said it was a 94 Dtre!…
                          @erion
                          E Offline
                          E Offline
                          erion
                          @SpookDog there is a raised surface between the carb and the suspension spring its the same as the frame number
                            E Offline
                            E Offline
                            erion
                            @SpookDog its not RE tho it doesnt have electric start
                            • E erion
                              @erion
                              Yeah, it should be if it’s a numbers matching, righteous bike 🙂
                              Has this bike ever been registered in the UK before? If it has I’d contact the DVLC and ask them. Or maybe try their website? If it’s not UK registered there are hoops you have to jump through that I know nothing about…
                              Someone here will know though 🙂 …
                                @erion
                                It might be a 94 bike then. They didn’t do RE’s till 2004 or 6
                                  @erion
                                  E Offline
                                  E Offline
                                  erion
                                  @SpookDog my relatives bought it in switzerland from a neighbour in 2006 i think and they imported it here in kosovo its should of been registered in swiss but by many chances we are the 2nd owners of the bike and that makes me think its a model that was exported to swiss
                                  • E erion
                                    @erion
                                    You are in Kosovo? Oh well I can’t help you bud! 🥴 …
                                      @erion
                                      E Offline
                                      E Offline
                                      erion
                                      @SpookDog im looking if i can derestrict it somehow thats why im looking to find the year model
                                      • E erion
                                        @erion
                                        Does your bike have a power valve servo fitted to it?
                                          @erion
                                          E Offline
                                          E Offline
                                          erion
                                          @SpookDog idk what the servo one is but it does have a pwer valve conected to the cylinder with 2 cables , can you explain what the servo is
