  3. 3MB head.... Should I buy it?
18 Posts 8 Posters 7.5k Views 1 Watching
  • MightymanM Mightyman
    You would need work done to that one... The pits in the centre are where loose metal has been smashed against it.
    @MIGHTYMAN said in 3MB head.... Should I buy it?:
    That OR engine detonated. Detonation is engine killer.
    Absolute waste of money buying that head it's fucked. You would have to have it worked, in which case you might as well get the 3BN head worked
    • AndyYamA
      AndyYamA
      AndyYam
      wanna buy a 4dl head?
      DartyD dtlukeD 2 Replies Last reply
      • AndyYamA AndyYam
        @AndyYam Yes.
        • AndyYamA AndyYam
          dtlukeD
          dtlukeD
          dtluke
          @AndyYam is the 4DL as good as the 3MB? I've just put on my third head gasket now (Athena gasket) and still have a leak so I'm guessing my 3bn is warped anyway 😞
          BurridgeB 1 Reply Last reply
            Look at this on eBay http://www.ebay.es/itm/302062068939
            dtlukeD 1 Reply Last reply
              dtlukeD
              dtlukeD
              dtluke
              wrote on last edited by dtluke
              @Calum thanks Calum, think I will go for that if you reckon its a good buy? I really can't find much info on the web about putting a 4dl head on a 3mb00 DTR barrel? I assume it will be an improvement over the 3bn - especially if minesl is warped!
              • dtlukeD dtluke
                Great find @Calum
                @dtluke Genuine Belgarda parts are the perverbial needles in hay stacks - nuff said!!! 😉
                • dtlukeD dtluke
                  BurridgeB
                  BurridgeB
                  Burridge
                  @dtluke said in 3MB head.... Should I buy it?:
                  Use a genuine Yamaha gasket when you put your new head on, a lot more money but it'll be worth it
                    The 4dl head sits on a 3mb barrel. Graham Bell says the head is where the majority of the power is made. Get that right and you can't go far wrong.
                    I have done many heads before and haven't had any problems with Athena. There is a tutorial on qhat you should do to prep the head and barrel using a sheet of glass and various grades of wet and dry paper. Do what I say in that turorial and it will seal.
                    • dtlukeD
                      dtlukeD
                      dtluke
                      Cheers guys, I have bought that head. Looking forward to it arriving
                      • AndyYamA
                        AndyYamA
                        AndyYam
                        I think i have 1-2 4DL heads sitting around in the garage. I'm away for a week in Wales as of monday. If i have time before then ill get photos up in the for sale section. If not it'll be when i get back.
                        What did that one on ebay go for? as a guide for price.
                        • kennymurphy97K
                          kennymurphy97K
                          kennymurphy97
                          Will a 1989 3MB head fit the 3MB barrel of my 2000 dt?
