  4. crank noise
crank noise
15 Posts 4 Posters 2.5k Views
  • E Offline
    E Offline
    erioni123
    hey doing a rebuild now and i have the barrel off and when i spin it by hand it makes a grinding noise is this okay ? i think it should spin without any noise
    https://imgur.com/gallery/PVuO4DT
    • MadGyverM Offline
      MadGyverM Offline
      @erioni123 Hi. It's not ok,it should spin freely and noiseless. You have to check/replace crankshaft bearings and the bottom big end bearing. I would change them all to be in piece of mind.
      • E erioni123
        @erioni123
        Ditto, definitely not. New main bearings and seals…
        E 1 Reply Last reply
          @erioni123
          E Offline
          E Offline
          erioni123
          @SpookDog i see koyo main bearings the pop up a lot when i search on google are they any good
          • E erioni123
            @erioni123
            They’re the ones to get. There is a type to get though, don’t get the ‘cs’ type (I think!)…
            CRB023
            These are the ones to get I think…
              PJME is your friend. Make sure you get the right clearances as well. C3 IIRC.
              Yamaha DT125R Crankshaft Main Bearing LH
              Yamaha DT125R Crankshaft Main Bearing RH
              I always replace all other gearbox bearings whilst you're there, but that's just me and my OCD.
                E Offline
                E Offline
                erioni123
                @Calum is there any way to split the cases without a case splitter as someone said that you can but i dont think you can
                  I've never used a case splitter. What is a case splitter?
                    E Offline
                    E Offline
                    erioni123
                    @Calumhow do i split the case tho, the cank case how do i split it apart to change the bearings
                      Undo the bolts, dismantle the clutch/generator and then gently tap the casings apart. I use a rubber mallet.
                        E Offline
                        E Offline
                        erioni123
                        @Calum how do you tap them apart like there is no place to hit it
                          There is a spot where the starter motor goes. And there is a piece up top near the inlet manifold.
                          It literally only needs a gentle tap.
                          The other good technique is just use the flywheel puller. These can be had on eBay for next to nothing and can even be made from scrap metal. It's well described in the Haynes.
                          • E erioni123
                            @erioni123
                            I don’t mean to offend.
                            Are you sure you’re up for this? Is this the first engine that you’ve worked on?
                            There are certain tools you need to dismantle the engine. Not to mention the damage you can do trying to remove bearings, even after you’ve successfully dismantled the casing…
                              @erioni123
                              E Offline
                              E Offline
                              erioni123
                              @SpookDog its my first time splitting cases but im not sure if i will do it myself maybe i'll have someone do the rest of the work just to be safer, but i saw that people use case spliters its a tool made for spliting them
                              • E erioni123
                                @erioni123
                                Like Callum said, use a flywheel puller to push the crank in and separate the cases. DO NOT use a screwdriver or chisel, please!…
                                A rubber mallet is usually enough for me…
