  4. hid headlight conversion
20 Posts 7 Posters 8.3k Views 1 Watching
    I run Xenon Halogens. Really really bright bulbs.
    • NINJAN
      The Xenon bulbs I linked earlier were super bright and had a cool blue tint to em too Plus you get 2 of em for £6.22 - absolute bargain. B)
      • britshgigoloB
        britshgigoloB
        britshgigolo
        did you get the 100/90w or the 60/55w version as need to get some better bulbs for mine
        • britshgigoloB britshgigolo
          @britshgigolo Are you asking me or @admiral323???
            Be careful with the 100W. That will offload a lot.of power to the rectifier. Better to.go off with a lower power one but perhaps warmee.
              Ehr, the rectifier burns uo unused current, so the more you need the easier a life it has.
              But the stator cant cope with 100W so the light will probably be dimmer than a 65w
              • britshgigoloB
                britshgigoloB
                britshgigolo
                well i ordered the 65w one so hope they will be ok nd give more light than the standard bulb
                  @britshgigolo The OEM bulb is only 45W, I had a 55-60W white bulb in mine before I switched to the 100/90W one. Even the 55W was an improvement over the stock bulb, which was more like a crappy house bulb and not the regular car type ones. But obviously not as good as the 90W. Which I ran with no problems on my DTR, but then maybe some problems would surface over the long term? Only time will tell I guess???
                  • britshgigoloB
                    britshgigoloB
                    britshgigolo
                    i got the 65w bulb and fitted but not tried it yet in the dark but looks lots better than the standard bulb but time will tell
                    • NINJAN
                      I spotted these on ebay, might be worth a shot and a decent price if there not to fiddely to fit???
                      http://www.ebay.co.uk/itm/222325896647?ul_noapp=true
                      • britshgigoloB
                        britshgigoloB
                        britshgigolo
                        would these not be the same as the ones posted above where the light is scattered and blind on coming vechles because of the reflecor
                          My standard headlight was really good!? Just not a bright white, Ran its original bulbs for years,
                            The headlight on the RE is really good too I thought. Even better when I bought some decent Xenon bulbs from Ring
