  3. Top End
  4. pinning power valve parts needed
24 Posts 5 Posters 6.2k Views
  • D Offline
    D Offline
    dan28
    I need to pin the pv I have no servo
    my pv has a diamond shape on the end
    heres a photo
    [URL=http://s84.photobucket.com/user/dan25_2006/media/11042017374.jpg.html][IMG]http://i84.photobucket.com/albums/k3/dan25_2006/11042017374.jpg[/IMG][/URL]
    now when I fit the metal bush with the slot in the diamond part still rotates inside the bush
    heres a photo
    [URL=http://s84.photobucket.com/user/dan25_2006/media/11042017375.jpg.html][IMG]http://i84.photobucket.com/albums/k3/dan25_2006/11042017375.jpg[/IMG][/URL]
    also when the bush an cap are on they seem to be too far away from the pv heres a photo
    [URL=http://s84.photobucket.com/user/dan25_2006/media/11042017376.jpg.html][IMG]http://i84.photobucket.com/albums/k3/dan25_2006/11042017376.jpg[/IMG][/URL]
      Fit it with the servo cup on. You can pin it on the cylinder wall.
        D Offline
        D Offline
        dan28
        @Calum said in pinning power valve parts needed:
        I m lost what part is the servo cup an which round does it fit
          Item 24 here
          https://www.ajsutton.co.uk/genuineparts/9028/1/yamaha-dt125re-2005/cylinder?uID=0
          • D Offline
            D Offline
            dan28
            That makes more sense now
            Only I don't have that part no wonder I couldn't figure it out
            • D Offline
              D Offline
              dan28
              So just to confirm I need the plastic pulley an the housing the cables go into
              So it can be pinned
              Is there another way of doing it as I m sure my 89 barrel had a cap either side an no pulley or cable housing
              A 1 Reply Last reply
              • ZrakoZ Offline
                ZrakoZ Offline
                Zrako
                Post a pic of side of your barrel where the valve is . Dont you have pulley housing at all?
                You can add it directly here by clicking on the small cloud with arrow inside it . Much easier. 😉
                1979 Jawa Mustang 50
                2003 Gilera DNA 125 R.I.P
                2015 Keeway TX 125 SM
                2006 Yamaha DT 125 X
                • D dan28
                  So it can be pinned
                  A Offline
                  A Offline
                  andrewj1680
                  @dan28 I have the early version the same as you if you pull the power valve cover off the left side of the cylinder there is a sleeve that slots over the top of the powervalve itself when you pull the sleave out there is a pin in it basically turn the valve 180 and put the sleeve back but insure you turn the sleeve the pin will need to locate in the top now rather than the bottom as long as you still have the pin in the collar you can't get it wrong however I have seen this pin removed where people without the know how have tried to open the power Valve and snapped it off
                    I don't have any experience with the non-servo operated valves so I couldn't say.
                    Might have halve a chance if you throw up some photos.
                    • A Offline
                      A Offline
                      andrewj1680
                      0_1492011942118_20170412_164057.jpg 0_1492011960496_20170412_164107.jpg 0_1492011975514_20170412_164342.jpg 0_1492011994455_20170412_164413.jpg
                        Nice, yeah no idea.
                        I'd buy the servo operated gubbins and pin it that way.
                        or go for something like this:
                        http://www.ebay.co.uk/itm/Yamaha-TZR-DT-125-manual-power-valve-adjuster-/122432325847?hash=item1c818908d7:g:aFYAAOSwq5pXQF9E
                        • Louis-DT-WRL Offline
                          Like callum says, use a servo. When one PV cable snapped, I pinned mine open until the new cable came. Makes it really loud and no bottom end power
                          • ZrakoZ Zrako
                            D Offline
                            D Offline
                            dan28
                            @Zrako said in pinning power valve parts needed:
                            You can add it directly here by clicking on the small cloud with arrow inside it . Much easier. 😉 I sold my 89 barrel that had the caps on it
                            An I also sold the 05 barrel that had the housing on
                            I sold them to buy the tdr r P stamped barrel an head off scrim
                            Now the only caps I have are the ones in the photo
                            • A andrewj1680
                              D Offline
                              D Offline
                              dan28
                              @andrewj1680 said in pinning power valve parts needed:
                              Any chance you can post of photo of your cap
                              • D dan28
                                A Offline
                                A Offline
                                andrewj1680
                                @dan28 the cap is included in the pics I've posted mate the cap has the pin in the base which then locks into the sleeve the sleeve slips over the power valve and mine doesn't spin inside it then the cap locks in place through the 2 holes where it bolts to the cylinder holding everything in place
                                • D Offline
                                  D Offline
                                  dan28
                                  sorry Andrew I didn't see those photos on my phone
                                  those parts look like mine 🙂
                                  I have the cap although the pin is missing
                                  an I have the sleeve
                                  am supposed to remove the bush with the orange rubber so the sleeve can slide on to the pv
                                  here are photos to explain
                                  • D dan28
                                    D Offline
                                    D Offline
                                    dan28
                                    @dan28
                                    that cloud / pic attach tool is awesome thanks calum
                                    • D dan28
                                      @dan28
                                      A Offline
                                      A Offline
                                      andrewj1680
                                      @dan28 turn that sleeve the other way mate and slot it over the valve
                                      • A Offline
                                        A Offline
                                        andrewj1680
                                        I'm sure that is the wrong power valve mate mine sits inside that sleeve where as looking at yours it won't
                                        • A Offline
                                          A Offline
                                          andrewj1680
                                          Looks like you have this 1
