  3. Top End
  4. pinning power valve parts needed
24 Posts 5 Posters 8.7k Views
  • ZrakoZ
    ZrakoZ
    Zrako
    Post a pic of side of your barrel where the valve is . Dont you have pulley housing at all?
    You can add it directly here by clicking on the small cloud with arrow inside it . Much easier. 😉
    1979 Jawa Mustang 50
    2003 Gilera DNA 125 R.I.P
    2015 Keeway TX 125 SM
    2006 Yamaha DT 125 X
    • D dan28
      So just to confirm I need the plastic pulley an the housing the cables go into
      So it can be pinned
      Is there another way of doing it as I m sure my 89 barrel had a cap either side an no pulley or cable housing
      A
      A
      andrewj1680
      @dan28 I have the early version the same as you if you pull the power valve cover off the left side of the cylinder there is a sleeve that slots over the top of the powervalve itself when you pull the sleave out there is a pin in it basically turn the valve 180 and put the sleeve back but insure you turn the sleeve the pin will need to locate in the top now rather than the bottom as long as you still have the pin in the collar you can't get it wrong however I have seen this pin removed where people without the know how have tried to open the power Valve and snapped it off
        I don't have any experience with the non-servo operated valves so I couldn't say.
        Might have halve a chance if you throw up some photos.
        • A
          A
          andrewj1680
          0_1492011942118_20170412_164057.jpg 0_1492011960496_20170412_164107.jpg 0_1492011975514_20170412_164342.jpg 0_1492011994455_20170412_164413.jpg
            Nice, yeah no idea.
            I'd buy the servo operated gubbins and pin it that way.
            or go for something like this:
            http://www.ebay.co.uk/itm/Yamaha-TZR-DT-125-manual-power-valve-adjuster-/122432325847?hash=item1c818908d7:g:aFYAAOSwq5pXQF9E
            • Louis-DT-WRL
              Louis-DT-WRL
              Like callum says, use a servo. When one PV cable snapped, I pinned mine open until the new cable came. Makes it really loud and no bottom end power
              • ZrakoZ Zrako
                dan28
                @Zrako said in pinning power valve parts needed:
                You can add it directly here by clicking on the small cloud with arrow inside it . Much easier. 😉 I sold my 89 barrel that had the caps on it
                An I also sold the 05 barrel that had the housing on
                I sold them to buy the tdr r P stamped barrel an head off scrim
                Now the only caps I have are the ones in the photo
                • A andrewj1680
                  dan28
                  @andrewj1680 said in pinning power valve parts needed:
                  Any chance you can post of photo of your cap
                  A 1 Reply Last reply
                  • D dan28
                    A
                    A
                    andrewj1680
                    @dan28 the cap is included in the pics I've posted mate the cap has the pin in the base which then locks into the sleeve the sleeve slips over the power valve and mine doesn't spin inside it then the cap locks in place through the 2 holes where it bolts to the cylinder holding everything in place
                    • D
                      dan28
                      sorry Andrew I didn't see those photos on my phone
                      those parts look like mine 🙂
                      I have the cap although the pin is missing
                      an I have the sleeve
                      am supposed to remove the bush with the orange rubber so the sleeve can slide on to the pv
                      here are photos to explain
                      • D dan28
                        dan28
                        @dan28
                        that cloud / pic attach tool is awesome thanks calum
                        • D dan28
                          @dan28
                          A
                          A
                          andrewj1680
                          @dan28 turn that sleeve the other way mate and slot it over the valve
                          • A
                            A
                            andrewj1680
                            I'm sure that is the wrong power valve mate mine sits inside that sleeve where as looking at yours it won't
                            • A
                              A
                              andrewj1680
                              Looks like you have this 1
                              • A
                                A
                                andrewj1680
                                You should have this 1
                                  Literally eitherfit the servo operated cable pulley and pin it, or buy that item I linked and pin it, or better still fit the servo.
                                  • A
                                    A
                                    andrewj1680
                                    You could always just stick a big washer behind the bolt that runs through the middle you can lock it off that way which is what I have ended up doing today as since having port work and the power valve modded it kept moving a little over fully open
                                    • A andrewj1680
                                      dan28
                                      I ve bought the servo kit I can use the standard parts to pin it now
                                      or if I can get the servo to fit my frame I will use it
                                      (the dt engine is in a different frame ) its gonna be a mission to get the servo to fit I wanted to mount it under the tank but the cables are too short
                                      not sure it will be worth the hassle
