  3. Bottom End
  4. Gearbox Oil Vanished!! 😂
Scheduled Pinned Locked Moved Bottom End
11 Posts 6 Posters 5.1k Views
  • CallumJ94C
    CallumJ94C
    CallumJ94
    My 03 DTR was filled with gearbox oil to 3/4 of the way up the viewing window 2 weeks ago. Noticed last night it's not showing on the window whatsoever even when it's leaned over. It hasn't mixed into the rad, all the cooling system is ok still. It hasn't been leaking anywhere. And it hasn't been smoking at all more than it ever has so I don't think it's burning it. Has anyone got any idea what the issue could be? Cheers.
    • Louis-DT-WRL
      Louis-DT-WRL
      Have you removed the drain plug and measured it?
      Could be leaking into the crank housing
      • MightymanM
        +1 definitely measure it as I've found the oil sight glass is hit or miss at times.
        • ZrakoZ
          ZrakoZ
          Zrako
          wrote on last edited by Zrako
          I have like 900+ ml in the bottom end and still have to tilt it towards right to see the level . Lots of oil is in the gearbox too . Haynes refer to 800ml after rebuild but still not enough for me. Tried to warm up engine and let it sit straight , tried to check after not running few days - same results - below inspection glass...
          Btw. - no leaks and coolant is clear too.
          1979 Jawa Mustang 50
          2003 Gilera DNA 125 R.I.P
          2015 Keeway TX 125 SM
          2006 Yamaha DT 125 X
          • F
            When i built my bike back up i put 850ml as per the manual. Took it for MOT and when i got home it had spat a loud of it out of the breather! I drained a fair bit out after that. Reads in the middle of the sight glass now
              Literally says 750ml on the clutch cover...
              Louis-DT-WRL F 2 Replies Last reply
                Louis-DT-WRL
                Louis-DT-WRL
                @Calum you're correct 900 is way too much
                • ZrakoZ
                  ZrakoZ
                  Zrako
                  Lol I know that 900 is too much . But dont want to fry new clutch , where is all the oil ?
                  • ZrakoZ Zrako
                    Louis-DT-WRL
                    Louis-DT-WRL
                    @Zrako roo much oil can be worse than not enough though
                      When you run too much oil you effectively allow the engine to whip it up, causing bubbles to form. This reduces the oils effectiveness greatly. Therefore, too much oil is just as bad as too little.
                        @Calum I did whatever it said on the cover, couldn't remember off the top of my head
