Wr200 engine into dtr
Quick test fit up before it gets rebuilt -
Direct fit exactly the same as the original motor along with the standard wr200 tm30ss carb atm and a dt230 airbox boot
Quick test fit up before it gets rebuilt@andrewj1680 WoW sweet straight swap FTW!!!
@andrewj1680 said in Wr200 engine into dtr:
what about the exhaust? is it stock or aftermarket? thinking of doing something similar
@harveymg there is a slight difference in shape so I'd guess you need the 200 exhaust but may need to adapt it to fit the 125 mounts
