  4. 1990 dtr oil pump 4fl completely slack?
26 Posts 4 Posters 5.1k Views 1 Watching
  • declanD Offline
    Hello guys first post and I'm in need of help I brought my dt a few days ago and I'm doing a lot of work on it and I noticed the oil pump cable is completely slack does this mean it's getting no oil at idle?
      The oil will still pump, but it does relate to the throttle position.
      If you were watching my video then it wants to be setup similar to that. I adjusted it so that even on idle it injects a little more.
      ZrakoZ 1 Reply Last reply
        ZrakoZ Offline
        ZrakoZ Offline
        Zrako
        @Calum post the link of the video please 😊 I did similar think. There is an adjuster for slack of the cable going to pump , I am tighten it few threads so its preloaded a bit , it should give more oil in.
        1979 Jawa Mustang 50
        2003 Gilera DNA 125 R.I.P
        2015 Keeway TX 125 SM
        2006 Yamaha DT 125 X
        MightymanM 1 Reply Last reply
        • ZrakoZ Zrako
          MightymanM Offline
          MightymanM Offline
          @Zrako https://www.youtube.com/watch?v=WwFUzgr2xnA
          • declanD Offline
            **)2_1493994662971_IMG_1005.JPG 1_1493994662971_IMG_1004.JPG 0_1493994662969_IMG_1003.JPG
              Yeah it looks like your cable or clutch cover id damaged. The oil cable should sit within the oil pump housing. Fastened both sides by a circlip and the cable itself.
                @Calum I'm just gonna use some metal bushings as spacers and hope for the best thank you for your help!.
                  @declan so it is really important that you don't bodge this part.
                  If the casing is damaged, I would be much more inclined to replace the clutch cover.
                  For the sake of £20
                  Look at this on eBay http://www.ebay.co.uk/itm/282440840878
                    For the sake of £20
                    @Calum already looked into it I originally thought the casing was broke but after looking around it turns out mines fine nothings broken I don't really understand it
                      @declan So the oil pump cable shouldn't fall through the cover. So.is the cable damaged.
                        @Calum not that I can see I've checked it over I found a video on YouTube that showed the exact same thing mine does but it was foreign so I couldn't tell if he was showing a fault or how it normally is
                          @declan You know what I am saying though?
                          The cable shouldn't be able to go all the way through. So that should tell you what has gone wrong.
                            @Calum yeah I know what your saying when the bikes all together I'll sort it
                            • MightymanM Offline
                              MightymanM Offline
                              Is it possible that the two cables have been swapped?!
                              • MightymanM Mightyman
                                @Mightyman It doesn't look that way, note the space for the circlip on the cable
                                  @Calum and there's no way it could have stretched that much surely
                                    @declan The cable isn't stretched. The whole thing has gone into the oil pump housing.
                                    The metal piece with the reecess cut out should be way back inside the cutaway. The circlip stops it falling back out of the case and it is stopped by the fact the whole cable does not fit inside the housing.
                                    I get the impression I am not making it very clear.
                                      @Calum no I completely understand that's why I mentioned the bushings to it takes up the cable slack
                                        @declan But I am saying, fix it. It should be fixed not padded out with bushes
                                        • ZrakoZ Offline
                                          ZrakoZ Offline
                                          Zrako
                                          This is how mine looks like. No circlips , basically it holds on a rubber o ring inside the bore and if I want I can pull it out.
