  4. 1990 dtr oil pump 4fl completely slack?
26 Posts 4 Posters 5.7k Views 1 Watching
  • ZrakoZ Zrako
    @Calum post the link of the video please 😊 I did similar think. There is an adjuster for slack of the cable going to pump , I am tighten it few threads so its preloaded a bit , it should give more oil in.
    @Zrako https://www.youtube.com/watch?v=WwFUzgr2xnA
    • declanD
      **)2_1493994662971_IMG_1005.JPG 1_1493994662971_IMG_1004.JPG 0_1493994662969_IMG_1003.JPG
        Yeah it looks like your cable or clutch cover id damaged. The oil cable should sit within the oil pump housing. Fastened both sides by a circlip and the cable itself.
          @Calum I'm just gonna use some metal bushings as spacers and hope for the best thank you for your help!.
            @declan so it is really important that you don't bodge this part.
            If the casing is damaged, I would be much more inclined to replace the clutch cover.
            For the sake of £20
            Look at this on eBay http://www.ebay.co.uk/itm/282440840878
              For the sake of £20
              @Calum already looked into it I originally thought the casing was broke but after looking around it turns out mines fine nothings broken I don't really understand it
                @declan So the oil pump cable shouldn't fall through the cover. So.is the cable damaged.
                  @Calum not that I can see I've checked it over I found a video on YouTube that showed the exact same thing mine does but it was foreign so I couldn't tell if he was showing a fault or how it normally is
                    @declan You know what I am saying though?
                    The cable shouldn't be able to go all the way through. So that should tell you what has gone wrong.
                      @Calum yeah I know what your saying when the bikes all together I'll sort it
                      • MightymanM
                        Is it possible that the two cables have been swapped?!
                        • MightymanM Mightyman
                          @Mightyman It doesn't look that way, note the space for the circlip on the cable
                            @Calum and there's no way it could have stretched that much surely
                              @declan The cable isn't stretched. The whole thing has gone into the oil pump housing.
                              The metal piece with the reecess cut out should be way back inside the cutaway. The circlip stops it falling back out of the case and it is stopped by the fact the whole cable does not fit inside the housing.
                              I get the impression I am not making it very clear.
                                @Calum no I completely understand that's why I mentioned the bushings to it takes up the cable slack
                                  @declan But I am saying, fix it. It should be fixed not padded out with bushes
                                  • ZrakoZ
                                    ZrakoZ
                                    Zrako
                                    This is how mine looks like. No circlips , basically it holds on a rubber o ring inside the bore and if I want I can pull it out.
                                    1979 Jawa Mustang 50
                                    2003 Gilera DNA 125 R.I.P
                                    2015 Keeway TX 125 SM
                                    2006 Yamaha DT 125 X
                                    • ZrakoZ Zrako
                                      @Zrako Nice, but there should be a circlip to stop it falling off.
                                      • declanD
                                        Is it okay to ask questions here or do I have to start a new thread?
                                          @declan If the question is related fine, if it's a totally new question then new thread please.
