  4. 1990 dtr oil pump 4fl completely slack?
26 Posts 4 Posters 5.6k Views 1 Watching
  • MightymanM Mightyman
    Is it possible that the two cables have been swapped?!
    @Mightyman It doesn't look that way, note the space for the circlip on the cable
      @Calum and there's no way it could have stretched that much surely
        @declan The cable isn't stretched. The whole thing has gone into the oil pump housing.
        The metal piece with the reecess cut out should be way back inside the cutaway. The circlip stops it falling back out of the case and it is stopped by the fact the whole cable does not fit inside the housing.
        I get the impression I am not making it very clear.
          @Calum no I completely understand that's why I mentioned the bushings to it takes up the cable slack
            @declan But I am saying, fix it. It should be fixed not padded out with bushes
            • ZrakoZ
              ZrakoZ
              Zrako
              This is how mine looks like. No circlips , basically it holds on a rubber o ring inside the bore and if I want I can pull it out.
              1979 Jawa Mustang 50
              2003 Gilera DNA 125 R.I.P
              2015 Keeway TX 125 SM
              2006 Yamaha DT 125 X
              • ZrakoZ Zrako
                @Zrako Nice, but there should be a circlip to stop it falling off.
                • declanD
                  Is it okay to ask questions here or do I have to start a new thread?
                    @declan If the question is related fine, if it's a totally new question then new thread please.
                    • declanD
                      Got it thank you
                        @Calum is there any chance you could take a picture of the hex bolt and thread so I know how it looks thanks.
                          Part 8
                          See where it leaves the junction box, bends 90 odd degrees and has some tiddly bits above it.
                          That's where you adjust it.
