portingignitech4dldtrwr200
135 Posts 27 Posters 144.0k Views 6 Watching
    wrote on last edited by Darty
    Decided against using the Kehin 36. Effort. it's not going to give me the right results. Went shopping, but I could not find anything suitable accept for a couple of Dell'orto VH34s or old TMX34's for reasonable price. Don't need anything bigger right now.
    Got this Mikuni TM32 which desperately needs a clean and polish. And a float bowl. It's been mangled.
    Who needs a digital display?
    Got this TZR Tachometer. Love the dial, goes to 12k. Yamaha part, perfect. You can always feel what the engine is doing, but it's nice to see what's going on. Not too useful, and it's rather big, but a single clock up front, clean, simple on the WR yoke.
    I prefer the Mikuni TM series + this version has the Fuel inlet on the right side. Wont bother with using the Airbox.
      So, gave up on the MOT. All because of a couple of Mikuni Pilot Jets. Postage took too long, could not finish it up.
      Jetting for an Open Air filter is a pain in the rear. Factory settings don't really apply and she's leaner than I anticipated. Which is kind of fun in a boring way. Jetting is the cheapest power you can buy! Best get it right.
      Dep header is swiss cheese so I wrapped it for now using Titanium fibre exhaust wrap. Operating temperature for the expansion pipe should be better? Hotter pipe to help control the temperature of exhaust gases. New pipe has to wait. Ah well. it's a Student build.
      Don't ever use that GumGum tape, pastey shite. Just awful on a header pipe.
      May have got impatient and dremel'd out the standard Inlet manifold. Pluged over the Oil injection entry and smoothed out and increased the bore size internally and opened the flange 28-32mm.
      Good thing about the standard manifold is the YIES boost bottle. Adds some much needed refinement to the 2 stroke.
      Increasing the bore I had to trim the bottom of the YIES snout as it protrudes further into the bore and will potentially disrupt airflow.
      The air filter and carb only just fits in and its bent around the YZ shocker. So tight and a bitch to get in and out.
      Running 520 YZ125 AFAM chain 13T drive sprocket and Talon 51T rear. Makes it perky. She sounds like a beast with and without the airbox amplifying it.
        @Darty haha nice one!
        • ConnorDTRC
          ConnorDTRC
          ConnorDTR
          I'm liking it!
          • Louis-DT-WRL
            Louis-DT-WRL
            Nice work there, liking the fabrication. I have often thought about a dt200r or wr200 swingarm but I spent ages getting the old bearings out of mine and powdercoating it so I left it. So it was a perfect fit you say? Except the dog bones.
            Fitting a different carburetor was also a nightmare, especially on a divided throttle cable (I'm running auto lube on my 200cx conversion) I had a tm32 flat side which was very tricky to fit because it isn't angle on the spigots. If you carb isn't level enough it can mess with the floats. I then ran a tmx30 carburetor very similar to the wr200s tm30ss carburetor which ran very nicely and few modifications. And I am currently running a tm34ss which has angled spigots. Which I'd recommend 🙂
            DartyD 1 Reply Last reply
            • Louis-DT-WRL Louis-DT-WR
              Ah cheers boys, @Calum @ConnorDTR there is still so much I need to do. Not enough time!
              @Louis-James Yeah, pretty much a perfect fit. I had to turn a spacer on the sprocket side of the swingarm because there is a gap between the bearing end cap and the crankcase, WR200 crankcase must have a wider section across the swingarm bolt.
              Fits fine without it, but needs the spacer for the correct lateral torque. But it's a bolt in job and I really recommend it.
              Definitely get yourself the WR200 linkage set (Alloy) I need to fit mine then you can potentially run very nice rear dampers from a newer generation. Got a nice TM Ohlins shock, looks to fit.
              The TM32 isn't a great fit, I've not run it for long, but it's possible it's already disrupting the floats. But fit for purpose just. Not ideal. Just had a look at some TM34Ss and yeah man, that looks to be a much better idea actually.
              Ultimately I think you have got too make a Inlet manifold, I can't fit anything else past the shock without one.
                Spring has crept around ol' Coventry today. Blessed. And then some bits finally turned up at lunch time.
                POWER.
                Most of Yamaha's road going production castings are begging to be cleaned up gone over properly, because the castings make you wince in places. They are cost effective without hand finishing and, of course the time and labour is not necessary for a production run. Not even because it's old, they need some love.
                Wrekt...She's a bit of a lemon. Cracked the sleeve to the top above the exhaust port. Still, new sleeve and some light repair work around the port and she's good to go. This will be the test mule for running a larger bore.
                Ignitech came through, I should of spec'd a longer loom so I could fit it into the now empty airbox. There isn't much of anywhere with decent access and tucked in.
                Looking forward to building up a 200R block.. maaybe some time on that.
                Anyone want some money for a WR200 powervalve they somehow don't need? I'm your man.
                • ConnorDTRC
                  ConnorDTRC
                  ConnorDTR
                  So what's the difference with the ignitech CDI and the Zeeltronic? Only just heard of the ignitechs
                    Very smart. Nice auxiliary exhaust ports on them too! Should be a beast.
                    Powervalves are tricky things to come by. I askrd about having one made but they simply wouldn't do it because of cost!
                    Very frustrating but I am sure you will find one one day!
                    Easy on how you remove that sleeve. Even companies have been known to damage the ally cylinder removing them.
                    Will.keep an eye out for updates.
                    • Louis-DT-WRL
                      Louis-DT-WRL
                      You can buy new sleeves on eBay, I saw some wiseco ones a few years back. I have the nickasil bore, not sure what models had what
                      • Louis-DT-WRL
                        Louis-DT-WRL
                        http://m.ebay.com/itm?itemId=231582562488&fromWatch=true
                          POWER.
                          Louis-DT-WRL
                          Louis-DT-WRL
                          @Darty I have a wr200 powervalve spare
                            @Louis-James Boss, got any quick pictures ?
                              Louis-DT-WRL
                              Louis-DT-WRL
                              @Darty I'll get some tomorrow I think it's baggy on the two joining downs but could be filled
                                Louis-DT-WRL
                                Louis-DT-WRL
                                @Dartyhttp://rs1083.pbsrc.com/albums/j388/louisgar/Mobile%20Uploads/DSC_0861_zpsufktz9sf.jpg?w=480&h=480&fit=clip
                                http://rs1083.pbsrc.com/albums/j388/louisgar/Mobile Uploads/DSC_0860_zpspkbzrqqw.jpg?w=480&h=480&fit=clip
                                • ConnorDTRC ConnorDTR
                                  #26
                                  @ConnorDTR The main difference is the interface design and the ZEELYS are bit more intuitive to use I reckon. But I like the software from Ignitech, you can just drag points across your curve and it's easy to fiddle with. For a Single cylinder PV anyway.
                                  Technically wise, Ignitech can prove less accurate and power valve control is not as good to setup as the ZEEL.. coming from some heavy tuners, but for average Joe bloggs, they are on par and the Ignitechs are way cheaper. I spec'd mine all in £115. Get a PC connector somewhere else.
                                    Moved to Correct Location
                                      #28
                                      My bike is a jumbled up. full UK spec late 3RMJ 2000/01' model. It's on a 03' plate and I think it was a demonstrator bike when new at a dealership, somewhere unknown unfortunately as I bought it with no history..
                                      This is well geeky, but I never ever see any DT's with imperial clocks? They are always Metric & Imperial, or just Metric. I don't want to know why.
                                      And yes before my Speedo drive snapped, my chassis components at least have covered over 27,000 miles. Not bad, I've seen clocks over 40,000 miles on older 3DB1 bikes.. Yikes.
                                      • Louis-DT-WRL
                                        Louis-DT-WRL
                                        Mines just imperial
                                          Mines just imperial
                                          @Louis-James Just checked mine was both.
