  3. Suspension
  4. Fork upgrade
Fork upgrade
7 Posts 4 Posters 3.8k Views 1 Watching
  • RickyR Offline
    RickyR Offline
    Ricky
    Hi guys can I fit ktm 400 forks to my dtx if I get the yoke and everything thanks
    DT 125X
      You can fit whatever you like, if you make it fit.
      It's a little more complicated than just swapping them forks over. But yeah I'm sure you can do it.
      RickyR 1 Reply Last reply
        RickyR Offline
        RickyR Offline
        Ricky
        @Calum cheers Calum think I'm going to go for the yz conversion but can I keep my wheels this is mine now 0_1499796381243_20170701_171616.jpg
        DT 125X
        CalumC N 2 Replies Last reply
        • RickyR Ricky
          @Ricky As said, you can keep all you want.
          Are you expecting it to be a straight swap? Cause it's not.
          The front and rear wheels MUST be kept inline.
          Not only that, but the front and rear sprockets too must be kept in line.
          You may find that with the wider track, that the rear wheel needs to be machined down to do this.
          I was fortunate, on my conversion, once the front and rear wheels were made inline, all I had to do was shim the sprocket.
          • RickyR Ricky
            N Offline
            N Offline
            @Ricky You would also most likely have to get a bearing cup machined up, for whichever forks you decide to use. @Calum made a tutorial for it here;
            https://dt125r.co.uk/topic/17/usd-conversion-bearing-cup-method
            • RickyR Offline
              RickyR Offline
              Ricky
              I'm going to leave the ktm what about the 2013 wr forks
              DT 125X
              • MightymanM Offline
                MightymanM Offline
                Might as well get some USD forks if you are going to be getting a new set to fit the bike, as most forks will need modifications done for correct fitting.
