  3. Welcome New Owners!
  4. New member
New member
27 Posts 10 Posters 8.7k Views 1 Watching
  • O oldman
    Going to keep I as original as possible within reason, the original exhaust is long gone unfortunately , has front section unrestricted as good as new, need to replace rear as a grotty old big one there originally. Swingarm seal guard broke when disassembled so that needs replacing, and platers lost swinger thrust cap but Fowlers were good for that. I fitted white pattern bodywork years ago so my son could ride it without me worrying about original panels, need to get the panels and tank out of loft but need replacement r/h side panel if memory serves as original heat damaged. Getting wheèls respoked shortly and replacing bearings and seals as I go, plan to use sparingly to be honest as I am aware not many of this vintage left, but will use it, can't beat the 2 stroke smell can you! Thanks for the welcome and will update as I progress but taking my time to get the right finish
    Paul
    @oldman welcome to the forum love your commitment to your bikes
    • britshgigoloB
      britshgigoloB
      britshgigolo
      welcome aboard mate
      • britshgigoloB britshgigolo
        welcome aboard mate
        scrimsmustang
        I have all the nos plastics in Red with genuine decals, and nos Red fuel tank still in the box. Although Red is a 1990 model only colour and has a silver frame. 88 3DB1 comes in white n red black n red or sky blue n yellow.
        • S scrimsmustang
          @scrimsmustang YES SCRIM!
          You still knocking about bud!
            Mine first registered 10/88, red bodywork and white frame, waiting for gasket set to complete engine and get that back in the frame
            CalumC S 2 Replies Last reply
            • O oldman
              @oldman Open up a build thread under the DTR section tell us more about it!
              • O oldman
                scrimsmustang
                @oldman said in New member:
                Impossible for an 88 3db1 to be Red from the factory, white frame 88 models are white or blue. Raspberry red bikes are 90 models only.
                  scrimsmustang
                  @Calum said in New member:
                  I take a look now and again Cal, sill got a few old dtr,s Got 2 nice ones on ebay now a black n green 90 model and a 91 violet n silver gray one " i really want to keep the violet one but it needs to go " Also have 2 88,s and an 01 tucked away 01 has yz topend carb airbox pipe and Tdr belgarda 3 spoke alloy wheels forks swinging arm and brembo brakes conversion..
                  MightymanM 1 Reply Last reply
                  • S scrimsmustang
                    @scrimsmustang the 01 sounds interesting.. You should stick a few pictures up in a thread, for old times sake 😉
                    • S
                      scrimsmustang
                      I might do but then i would have to get involved again lol,
                      • S scrimsmustang
                        @scrimsmustang how does the yz top end go? Stock crank etc??
                        • S scrimsmustang
                          @scrimsmustang Yeah, and we need you involved!
                          Are you keeping well now Scrim?
                          • tunertomT
                            tunertomT
                            tunertom
                            wrote on last edited by tunertom
                            YZ top end? i thought the intake was bolted to the cylinder on certain years of those? or am i missing something? what year and what mods to fit?
                            • tunertomT tunertom
                              @tunertom It's on the other forum. He modified the powervalve so it could be operated via the YPVS IIRC...
                                scrimsmustang
                                @tunertom said in New member:
                                91 topend, just drops straight on. Upto you how you operate the yz mechanical ypvs i use a fine adjusted 3 wire servo bolted on exhaust side of bike. Modified 91 yz inlet manifold etc etc. All details were on old forum
                                • S scrimsmustang
                                  @scrimsmustang Scrim you got a link to show everyone 😄
                                    scrimsmustang
                                    No dont think anything is on old forum anymore
                                    DartyD O 2 Replies Last reply
                                    • S scrimsmustang
                                      @scrimsmustang 1988' 2VN00 YZ barrel, I've seen this idea done before, but never the details with operating the Power Valve.
                                      I for one, would love to have a peek!
                                      • S scrimsmustang
                                        @scrimsmustang Hi, sent you a pm BTW RE bodywork. Listed as red on the logbook, owner known to me who had from 94 until came to me, is it possible to get info on original build colour?
                                        • tunertomT
                                          tunertomT
                                          tunertom
                                          http://dt125r.activeboard.com/t58917759/90-yz125-topend-onto-dtr/
                                          here is link to the page, you need to login to see it
                                          scrim? do you have any pictures of this completed you can share please???
