  4. What is the pre mix equivalent to the autolube at idle
38 Posts 9 Posters 8.5k Views 1 Watching
    @Calum what I'm asking is what amount would you reccomend I put in to richen the oil mix in conjunction with the oil pump currently I'm running 150ml to 5l with the oil pump and it seems like 50ml with the oil pump would be decent I know it's not a very straight forward question but I'm just gauging your opinion and input as all of this is a learning experience for me thank you.
    @declan Why are you adding oil to the fuel?
    150ml to 5L of fuel, dayum, that's like no oil pump territory.
      @Calum some say I have trust issues 😉
      I have no answer to that TBH
        @declan Yeah well it's going to foul plugs at that rate mate. Which means it's going to break down and run like a dog.
          @Calum honestly it don't smoke any more than it did but yeah I hear ya mate I'll rectify it
          • MightymanM
            Running that much oil with the pump as well is seriously pointless. If the pump is working correctly there is no need to be putting more oil into the fuel. I put double my usual amount of oil into my KTM 250 EXC a couple years back and I'm pretty sure it was the cause of the piston seizing, about 15 minutes into riding.
            • MightymanM Mightyman
              @Mightyman Gums up the piston rings causing them to stick.
              Also fouls the plugs. It's going to cause more problems than it's worth.
                @declan Please follow the Manufacturer recommendations first before asking any of us.
                It's best to 'guestimate' a healthy oil supply from that. But, from experience, as less oil you can work with the better!
                I run my DT on a 42:1 mixture still. These road going 2strokes just don't require heavy lubrication.
                MightymanM declanD 2 Replies Last reply
                  @Darty true! And tbh even today's Mx bikes don't need a ridiculous amount of oil. KTM recommends 50:1 with most of their line up. I think the freeride series are even less like 80:1???
                  Just read their newer bikes are on 80:1 with some people even going as low as 100:1 !
                  DartyD 1 Reply Last reply
                    @Darty thanks guys
                      @Mightyman I was reading in Motocross Action Magazine that Husqvarna were recommending going from 40:1 to 60:1 to fix the jetting issues the MXA test team were having when running the 2017' TC250.
                      And it it worked! Incredible for a complete MX race engine.
                        @Darty I wonder if that's because competition 2 strokes have a shitty service life so they only need to last a race before rebuild since leaner is faster in most cases
                        MightymanM DartyD 2 Replies Last reply
                          @declan yeah that is probably also the case.
                            @declan Not quite,
                            A leaner burn can still give the right operating temperature as the fuel is taking slightly more heat away from the cylinder walls.
                            But yes, as more friction occurs, more heat is generated and thermal expansion will eat into your cylinder tolerances quicker than a richer mixture.
                            It's hard to say, cylinder fill being very efficient nowadays!
                              jgr72
                              Does the carb size effect to autolube system? What I mean, is do you have to do something if you change original 28mm carb to for example 30 or 32mm? Vacuum is lower, but does it effect to a quantity of oil feeded?
                                I've seen people run 2% premix together with the oilpump for breaking in a piston.
                                People did that back in our moped days aswell.
                                But for everyday use, no point. If you dont trust your oilpump, take it off.....Youre adding oil anyway, so why dont you?
                                People seem so over-cautios about too much oil, i think theres a lot of information, floating around from back in the days with gummy been oil, that broke down and seperated from the gas if it was let to sit for a long period. This isn't racebikes, its everyday-bikes, they will run on a 5% premix, with a quarter of the gas beeing diesel. Tough reliable bikes.
                                Anyways, my guess is, at idle, the pump is flowing 1% or less.
                                  jgr72
                                  When I bought my bike, earlier owner says he have always put about 1% 2t oil into gas tank just to prevent engine hang (or ho do you say it in english?) and rest will be feeded by autolube. I did't put annything in gas, cause I trusted autolube. But what makes me think is the carb change...
                                  • J jgr72
                                    @jgr72 I'm running a 4mm bigger carb no worries. My brother ran a 38mm carb no problems.
                                    So I don't think it'll be an issue bud.
                                      jgr72
                                      Okey, that was my thought! Just wanted to be sure!
                                      • terry.tzT
                                        terry.tzT
                                        terry.tz
                                        my rs use to eat plugs at first like that bad I carried a few and the tools every where I went I mean I would still carry plugs anyway with a 2 stroke but the point is it was because of too much oil and it would be a pain every time you was in a hurry and ran like shit after a few rides if I was you I would pick one or the other you're gonna have a bad time in the rain at the side of the road a few times if not
                                        • Irongamer727I
                                          Lending the thread a bit. Since I will be running the 170 kit, which Athena recommends 3% oil to, I'm not sure what to do. I know the majority just relies on the autolube and so do I want. From my understanding theses engines don't require massive amounts of lubrication. I won't use the bike for racing all the time. Mostly getting from A to B on a nice reliable Dt. That being said, I want to be able to twist the throttle without being scared of it seizing. During the run in, my idea is to mix 1% oil in the tank and also go with the oil pump. Then later go down to just the pump. What do you think?
