  4. 2002 dt125r rev limit??
39 Posts 8 Posters 11.0k Views 1 Watching
    It's the powervalve bud.
    • M
      M
      Mitch_350z
      What do I need to do?? I've read assorted to do with a reed valve switch and powervalve wires??
      Cheers Mitch
      • M Mitch_350z
        Cheers Mitch
        @mitch_350z quickest, dirtiest solution would be to diwconnect the servo, pin the valve so it is flush with the exhaust port, then ride it.
        M 1 Reply Last reply
          M
          M
          Mitch_350z
          @calum oh right is there any way I could solve it without loosing bottom end power??
          Cheers Mitch
          • M Mitch_350z
            Cheers Mitch
            @mitch_350z Yeah fix the servo. But doing this will help to identify the faulty component.
            declanD M 2 Replies Last reply
              @ does it do the cleaning cycle?
                M
                M
                Mitch_350z
                @calum I don't think there is a fault with the servo?? It works perfectly fine upto around 7000rpm??
                  M
                  M
                  Mitch_350z
                  @declan yeah it does the cleaning cycle as normal so seems to be working
                  • M Mitch_350z
                    @mitch_350z It shouldn't close at 7000 mate, not even restricted. Restricted dtre's close at 10.
                    Sounds to me like it is simply not setup right. Closing when it should be opening.
                      M
                      M
                      Mitch_350z
                      @calum I've set the pv flush with the top of the exhaust port it's a little off the 'u' and hole behind the cover but is spot on?? I'm running out of ideas??
                      Cheers Mitch
                      • M Mitch_350z
                        Cheers Mitch
                        @Calum wait a min buddy are you telling me my dt is still restricted it redlines around 8.5?
                          @declan Yeah should pull to around 12 mate.
                          @Mitch_350z So long as its flush with the exhaust port that's the main thing.
                          How does it ride now?
                            @calum I know this is the most asked question but I've not seen no reed switch do you want me to start a new thread?
                              @declan Open up a new thread bud please.
                                M
                                M
                                Mitch_350z
                                @calum it seems to ride better when pinned but still only does 65 max and doesn't pull too well in 6th?? Struggles a little to rev up to but don't know If this is because of the pinning??
                                • M Mitch_350z
                                  @mitch_350z It shouldn't pull well at the lower RPMs, but past 6 it should pull hard to 12. If it doesn't then it's not the powervalve causing the problem.
                                    M
                                    M
                                    Mitch_350z
                                    @calum ok thanks mate I'll have to do a bit more digging, just out of curiosity my other dtr I had was also a 2002 but had a 3 wire servo rather than the 5 wire this one has?? What difference does this make??
                                    Cheers Mitch
                                      Everybody has to remember that 99' onwards 3RM DT's are CDI restricted to 8,500 RPM...
                                      So, don't expect anything like a 3 wire servo Pre 96' model.
                                      CalumC F 2 Replies Last reply
                                        @darty The DTRE's are not restricted to 8500. The DTR's may be.
                                          @darty definitely not, my DTX goes way past that.
