  4. 2002 dt125r rev limit??
39 Posts 8 Posters 11.0k Views 1 Watching
  • M Mitch_350z
    @calum I don't think there is a fault with the servo?? It works perfectly fine upto around 7000rpm??
    @mitch_350z It shouldn't close at 7000 mate, not even restricted. Restricted dtre's close at 10.
    Sounds to me like it is simply not setup right. Closing when it should be opening.
    M 1 Reply Last reply
      M
      M
      Mitch_350z
      @calum I've set the pv flush with the top of the exhaust port it's a little off the 'u' and hole behind the cover but is spot on?? I'm running out of ideas??
      Cheers Mitch
      • M Mitch_350z
        Cheers Mitch
        @Calum wait a min buddy are you telling me my dt is still restricted it redlines around 8.5?
          @declan Yeah should pull to around 12 mate.
          @Mitch_350z So long as its flush with the exhaust port that's the main thing.
          How does it ride now?
          declanD M 2 Replies Last reply
            @calum I know this is the most asked question but I've not seen no reed switch do you want me to start a new thread?
              @declan Open up a new thread bud please.
                M
                M
                Mitch_350z
                @calum it seems to ride better when pinned but still only does 65 max and doesn't pull too well in 6th?? Struggles a little to rev up to but don't know If this is because of the pinning??
                • M Mitch_350z
                  @mitch_350z It shouldn't pull well at the lower RPMs, but past 6 it should pull hard to 12. If it doesn't then it's not the powervalve causing the problem.
                    M
                    M
                    Mitch_350z
                    @calum ok thanks mate I'll have to do a bit more digging, just out of curiosity my other dtr I had was also a 2002 but had a 3 wire servo rather than the 5 wire this one has?? What difference does this make??
                    Cheers Mitch
                      Everybody has to remember that 99' onwards 3RM DT's are CDI restricted to 8,500 RPM...
                      So, don't expect anything like a 3 wire servo Pre 96' model.
                      CalumC F 2 Replies Last reply
                        @darty The DTRE's are not restricted to 8500. The DTR's may be.
                          @darty definitely not, my DTX goes way past that.
                            @finnerz89 Well, I wouldn't say WAY past. I think it's 10k. Because the Powervalve closes then and then it really struggles. But it's as simple as earthing the black and green wire then you get full power.
                            F 1 Reply Last reply
                              @calum I've had 12k a couple of times. Earthing that cable transformed it
                              DartyD 1 Reply Last reply
                                wrote on last edited by Darty
                                #28
                                @finnerz89 Yeah sick, the DTRs though - are different sadly.
                                DTRE/X use a non Restricted CDI.
                                2002''s are doomed to 8.5k.
                                NINJAN M 2 Replies Last reply
                                  @darty My '03 was de-restricted and went up to 11K+ NP's. 🙂
                                    @cyber-ninja Tell you what, it's said that there were some 3RM CDI's that were Unrestricted from factory for last model 2003'
                                    I can't remember the CDI code, if you had one, that was pretty rare!
                                    NINJAN Sgt Robuck 5S 2 Replies Last reply
                                      @darty I can't answer that for you as I sold the bike, but if it was an un-restricted CDI then yes I was very lucky indeed!! 🙂
                                        M
                                        M
                                        Mitch_350z
                                        @darty could this be as simple as swapping the cdi for an unrestricted one or is this not possible??
                                          My brother had a 2001 DTR and it was slow as fook.
                                          Although once derestricted it went like stink.
                                          Pretty sure he swapped out the CDI though.
