  4. 2002 dt125r rev limit??
39 Posts 8 Posters 10.5k Views 1 Watching
    Everybody has to remember that 99' onwards 3RM DT's are CDI restricted to 8,500 RPM...
    So, don't expect anything like a 3 wire servo Pre 96' model.
    CalumC F 2 Replies Last reply
      @darty The DTRE's are not restricted to 8500. The DTR's may be.
        @darty definitely not, my DTX goes way past that.
          @finnerz89 Well, I wouldn't say WAY past. I think it's 10k. Because the Powervalve closes then and then it really struggles. But it's as simple as earthing the black and green wire then you get full power.
          F 1 Reply Last reply
            @calum I've had 12k a couple of times. Earthing that cable transformed it
            DartyD 1 Reply Last reply
              wrote on last edited by Darty
              #28
              @finnerz89 Yeah sick, the DTRs though - are different sadly.
              DTRE/X use a non Restricted CDI.
              2002''s are doomed to 8.5k.
              NINJAN M 2 Replies Last reply
                @darty My '03 was de-restricted and went up to 11K+ NP's. 🙂
                  @cyber-ninja Tell you what, it's said that there were some 3RM CDI's that were Unrestricted from factory for last model 2003'
                  I can't remember the CDI code, if you had one, that was pretty rare!
                  NINJAN Sgt Robuck 5S 2 Replies Last reply
                    @darty I can't answer that for you as I sold the bike, but if it was an un-restricted CDI then yes I was very lucky indeed!! 🙂
                      M
                      M
                      Mitch_350z
                      @darty could this be as simple as swapping the cdi for an unrestricted one or is this not possible??
                        My brother had a 2001 DTR and it was slow as fook.
                        Although once derestricted it went like stink.
                        Pretty sure he swapped out the CDI though.
                          @calum do most still have the reed valve behind the clock or is that only for speed not revs?
                            #35
                            @declan I believe that it's a sensor which forms part of the de-restriction system. It monitor's RPM's and when a set limit is reached it retards the CDI/engine from going any higher. Hence if you unplug the sensor then in theory your engine is capable of reaching it's highest maximum RPM.
                            declanD M 2 Replies Last reply
                              @cyber-ninja I have no reed switch I have no grey box in front of the oil tank but my bike is a pre 99 I can't find any restrictions 😐
                                M
                                M
                                Mitch_350z
                                @cyber-ninja I have moved the reed switch behind the speedo but not unplugged anything??
                                  Sgt Robuck 5S
                                  Sgt Robuck 5S
                                  Sgt Robuck 5
                                  @darty They are rare? I currently have a dtr 125 2002 (Registered as a 2003)
                                  • Sgt Robuck 5S Sgt Robuck 5
                                    @sgt-robuck-5 you don’t see too many of that era of dt I don’t know if there rare I’m just speaking from experience in looking to buy although you will find them usually it’s an older
                                    Model that you will come across
