  4. 2002 dt125r rev limit??
39 Posts 8 Posters 11.0k Views 1 Watching
    @darty definitely not, my DTX goes way past that.
    @finnerz89 Well, I wouldn't say WAY past. I think it's 10k. Because the Powervalve closes then and then it really struggles. But it's as simple as earthing the black and green wire then you get full power.
    F 1 Reply Last reply
      @calum I've had 12k a couple of times. Earthing that cable transformed it
      DartyD 1 Reply Last reply
        wrote on last edited by Darty
        #28
        @finnerz89 Yeah sick, the DTRs though - are different sadly.
        DTRE/X use a non Restricted CDI.
        2002''s are doomed to 8.5k.
        NINJAN M 2 Replies Last reply
          @darty My '03 was de-restricted and went up to 11K+ NP's. ๐Ÿ™‚
            @cyber-ninja Tell you what, it's said that there were some 3RM CDI's that were Unrestricted from factory for last model 2003'
            I can't remember the CDI code, if you had one, that was pretty rare!
            NINJAN Sgt Robuck 5S 2 Replies Last reply
              @darty I can't answer that for you as I sold the bike, but if it was an un-restricted CDI then yes I was very lucky indeed!! ๐Ÿ™‚
                M
                M
                Mitch_350z
                @darty could this be as simple as swapping the cdi for an unrestricted one or is this not possible??
                  My brother had a 2001 DTR and it was slow as fook.
                  Although once derestricted it went like stink.
                  Pretty sure he swapped out the CDI though.
                    @calum do most still have the reed valve behind the clock or is that only for speed not revs?
                      #35
                      @declan I believe that it's a sensor which forms part of the de-restriction system. It monitor's RPM's and when a set limit is reached it retards the CDI/engine from going any higher. Hence if you unplug the sensor then in theory your engine is capable of reaching it's highest maximum RPM.
                      declanD M 2 Replies Last reply
                        @cyber-ninja I have no reed switch I have no grey box in front of the oil tank but my bike is a pre 99 I can't find any restrictions ๐Ÿ˜
                          M
                          M
                          Mitch_350z
                          @cyber-ninja I have moved the reed switch behind the speedo but not unplugged anything??
                            Sgt Robuck 5S
                            Sgt Robuck 5S
                            Sgt Robuck 5
                            @darty They are rare? I currently have a dtr 125 2002 (Registered as a 2003)
                            • Sgt Robuck 5S Sgt Robuck 5
                              @sgt-robuck-5 you donโ€™t see too many of that era of dt I donโ€™t know if there rare Iโ€™m just speaking from experience in looking to buy although you will find them usually itโ€™s an older
                              Model that you will come across
