  4. Need help
Need help
167 Posts 11 Posters 99.0k Views
  • NottsbikerN
    NottsbikerN
    Could be a conflict between old generators and new CDI's (for example) but with that amount of money being spent on it chances are its now something relatively simple
    I do however appreciate how frustrating these problems can be at time and how you want to murder someone when you've taken a carb apart 58 times 😉
    • V
      V
      vtrn_raptor
      Just done a compression test and it's at 100psi is that low ?
      • V
        V
        vtrn_raptor
        And the spark plug is black was a brand new one
        CalumC terry.tzT 2 Replies Last reply
        • V vtrn_raptor
          @vtrn_raptor Sounds like it's running rich. Is it sooty? Could be too much oil.
          Two strokes don't have too much compression.
          • V
            V
            vtrn_raptor
            I'll take a photo now
            • V vtrn_raptor
              terry.tzT
              terry.tzT
              terry.tz
              @vtrn_raptor really start from scratch your only confusing your self more it does sound like your running rich like @Calum said but I would not say that as you have still not put a picture of the plug up or taken a video and it could and most likely is too much fuel and that's why I said to run the bike for 10 sec's and take a picture as your descriptions are bad but considering that your at least trying I will tell and show you the differents alt text
              • terry.tzT
                terry.tzT
                terry.tz
                • V
                  V
                  vtrn_raptor
                  terry.tzT 1 Reply Last reply
                  • terry.tzT
                    terry.tzT
                    terry.tz
                    the top one is a plug with too much oil
                    the bottom one is too much fuel
                    which one is your closest too
                    • V vtrn_raptor
                      terry.tzT
                      terry.tzT
                      terry.tz
                      @vtrn_raptor I can't see the picture very well but yes that looks like a plug from too much fuel wet
                      • V
                        V
                        vtrn_raptor
                        Do you use Instagram ? As could send you a video of what the bikes doing on their
                        • terry.tzT
                          terry.tzT
                          terry.tz
                          no can you not put them on youtube
                          • V
                            V
                            vtrn_raptor
                            https://youtu.be/n9OW-WKmC5U
                            • V
                              V
                              vtrn_raptor
                              It's like this while riding won't go past 20mph soon as I let of the throttle it dies
                              • V vtrn_raptor
                                terry.tzT
                                terry.tzT
                                terry.tz
                                @vtrn_raptor yey now people can help you and this could be a few things don't think you will have a hard time solving this one I personally think that is a fuel problem what is it like at idle and building up to 6k and can it be a pain to start sometimes
                                whats it like on and off choke take your time to answer
                                • F
                                  Will it start without choke?
                                    terry.tzT
                                    terry.tzT
                                    terry.tz
                                    watch the video from 9-10 seconds a few times is that me or did that flood it self
                                      That looks and sounds like it's overfueling to fook.
                                      Quick check, remove the snorkel, does it get better or worse. Restrict the airbox, does it get better.
                                        terry.tzT
                                        terry.tzT
                                        terry.tz
                                        @calum good call if you watch the vid closely it Boggs out at 2k ish
                                        • V
                                          V
                                          vtrn_raptor
                                          Idles fine until giving throttle will gradually build up to 6k and even past it but does what happens in the vid if you give it full throttle with choke on it dies instantly but will start with it on but have to turn it off usually starts first kick from cold I'll take the snorkel off in a sec and give it a go
                                          F 1 Reply Last reply
