  4. Need help
Need help
167 Posts 11 Posters 99.0k Views
  • V
    V
    vtrn_raptor
    And the spark plug is black was a brand new one
    CalumC terry.tzT 2 Replies Last reply
    • V vtrn_raptor
      @vtrn_raptor Sounds like it's running rich. Is it sooty? Could be too much oil.
      Two strokes don't have too much compression.
      • V
        V
        vtrn_raptor
        I'll take a photo now
        • V vtrn_raptor
          terry.tzT
          terry.tzT
          terry.tz
          @vtrn_raptor really start from scratch your only confusing your self more it does sound like your running rich like @Calum said but I would not say that as you have still not put a picture of the plug up or taken a video and it could and most likely is too much fuel and that's why I said to run the bike for 10 sec's and take a picture as your descriptions are bad but considering that your at least trying I will tell and show you the differents alt text
          • terry.tzT
            terry.tzT
            terry.tz
            • V
              V
              vtrn_raptor
              terry.tzT 1 Reply Last reply
              • terry.tzT
                terry.tzT
                terry.tz
                the top one is a plug with too much oil
                the bottom one is too much fuel
                which one is your closest too
                • V vtrn_raptor
                  terry.tzT
                  terry.tzT
                  terry.tz
                  @vtrn_raptor I can't see the picture very well but yes that looks like a plug from too much fuel wet
                  • V
                    V
                    vtrn_raptor
                    Do you use Instagram ? As could send you a video of what the bikes doing on their
                    • terry.tzT
                      terry.tzT
                      terry.tz
                      no can you not put them on youtube
                      • V
                        V
                        vtrn_raptor
                        https://youtu.be/n9OW-WKmC5U
                        • V
                          V
                          vtrn_raptor
                          It's like this while riding won't go past 20mph soon as I let of the throttle it dies
                          • V vtrn_raptor
                            terry.tzT
                            terry.tzT
                            terry.tz
                            @vtrn_raptor yey now people can help you and this could be a few things don't think you will have a hard time solving this one I personally think that is a fuel problem what is it like at idle and building up to 6k and can it be a pain to start sometimes
                            whats it like on and off choke take your time to answer
                            • F
                              Will it start without choke?
                                terry.tzT
                                terry.tzT
                                terry.tz
                                watch the video from 9-10 seconds a few times is that me or did that flood it self
                                  That looks and sounds like it's overfueling to fook.
                                  Quick check, remove the snorkel, does it get better or worse. Restrict the airbox, does it get better.
                                    terry.tzT
                                    terry.tzT
                                    terry.tz
                                    @calum good call if you watch the vid closely it Boggs out at 2k ish
                                    • V
                                      V
                                      vtrn_raptor
                                      Idles fine until giving throttle will gradually build up to 6k and even past it but does what happens in the vid if you give it full throttle with choke on it dies instantly but will start with it on but have to turn it off usually starts first kick from cold I'll take the snorkel off in a sec and give it a go
                                      F 1 Reply Last reply
                                      • terry.tzT
                                        terry.tzT
                                        terry.tz
                                        what it idle at
                                        • V
                                          V
                                          vtrn_raptor
                                          Around 1.5-2k
